Introduction: DIY 3D Rose Tree Candle: an Elegant Valentine's Day Gift Idea-Guide
Look no further for the perfect handmade gift or holiday centerpiece! In this tutorial, I will show you how to make a gorgeous, intricate Rose Tree Candle.
The secret to this project lies in two things: a high-quality silicone mold that captures every petal detail, and a special painting technique using candle varnish to give it a shimmering, pearlescent finish. Whether you are a beginner or a pro, you can achieve this professional look at home.
Let's get started!
Materials:
  1. Soy Wax or Beeswax: (Choose a pillar blend for structural integrity)
  2. Candle Wick: Cotton wick suitable for 3-inch diameter candles.
  3. Fragrance Oil: (Optional, I used Rose & Sandalwood)
  4. Candle Dye: (Optional, if you want a colored base)
  5. Candle Varnish/Paint: Pearl, Gold, and Pastel colors
Tools:
  1. Silicone Mold: I used the [Rose Tree Silicone Mold by Boowan Nicole]
  2. Note: I highly recommend this specific mold because it is made of soft silicone, making it incredibly easy to demold without breaking the delicate rose petals.
  3. Double Boiler: For melting wax.
  4. Thermometer
  5. Wick Holder (or a wooden stick/chopstick)
  6. Fine Paintbrushes
Step 1: Preparing the Mold & Wicking
11:Wicking: First, thread your cotton wick through the pinhole at the bottom of the silicone mold. (Using a wicking needle makes this effortless!)
2:Securing the Support Shell: Next, place the soft silicone mold inside the rigid plastic support shell and lock it tight with binder clips.
Why is the support shell important?
  1. The hard shell acts as a skeleton. It keeps the intricate 3D contours of the tree perfectly upright and symmetrical, preventing the candle from leaning or warping as the hot wax cures.
  2. Safety & Consistency: This secure setup prevents wax leakage (safety first!) and ensures every single candle turns out identical and professional.
Step 2: Melting and Pouring
Melt your wax in a double boiler until it reaches around 185°F (85°C).
Add your fragrance oil and stir gently for 2 minutes.
Let the wax cool slightly to the recommended pouring temperature for your wax type (usually around 135°F - 150°F).
Slowly pour the wax into the mold. Tap the sides of the mold gently to release any trapped air bubbles, ensuring the wax fills every rose petal crevice.
Let it set. Patience is key! Allow the candle to cure for at least 4-6 hours (or overnight).
Step 3: Demolding
Once the wax is completely cool and hard, remove the wick holder.
Gently peel back the silicone mold.
Because the is flexible, you can roll it down carefully. The detailed roses should pop out perfectly without chipping.
Step 4: The Magic Touch - Painting
This is where your candle goes from "nice" to "masterpiece."
Using specialized candle varnish (or mica powder mixed with a tiny bit of rubbing alcohol), squeeze small amounts of paint onto a palette.
Use a fine brush to highlight the edges of the rose petals.
Creative Idea: You don't have to paint the whole tree! You can leave the wax creamy white and paint the roses in pastel pinks, blues, and greens with a pearlescent finish.
This adds depth and makes the texture of the mold really shine.
Step 5: Finished Result
These make incredible Christmas gifts, wedding favors, or home decor items. The light reflects beautifully off the pearlescent paint when the candle is lit.
And if you want to try this exact design, don't forget to check out the Rose Tree Candle Silicone Mold Collection – Boowan Nicole for the mold used in this tutorial. Happy crafting!Boowan Nicole
Step 6:
