DIY $5 Heated Chicken Waterer
Intro: DIY $5 Heated Chicken Waterer
As soon as the temps drop below freezing, we Minnesota farmers break out the winter gear. My least favorite contraption is the chicken waterer. In the summer, I hook a hose up to drip waterers and never have to think about it all summer. In the winter, I switch to a regular gravity-fed bucket. But it turns to a bucket of ice within a few hours if I don’t keep it heated.
Every year I hunt for a better solution. I’ve tried every DIY project out there, but nothing works better than this simple design I came up with a few years ago. It’s also dirt cheap.
STEP 1: Cut Out Wooden Base
First we need to create a base to hold everything together. Trace around the #10 can on a piece of wood. Next, use a jigsaw to cut it out. Make sure to cut inside the line by about 1/8″, the can has to fit over the wood. Finally, drill a 1″ to 2″ hole in the center of the base.
STEP 2: Wire Light Fixture
DISCLAIMER: Be sure to follow state electrical codes. Improper wiring can cause fires. If you are uncomfortable wiring a circuit yourself, find someone to help you.
Cut off the female end of the extension cord and remove wire insulation at the ends. Next, connect the wire ends to the fixture. Now test the connection by plugging it in.
STEP 3: Putting It All Together
Slide the extension coord through the hole in the wooden base and fasten the fixture to the base. Slide the #10 can over the base, closed side up. If the fit is not snug, use screws to hold in place.
You should feel warmth instantly when plugged in.
STEP 4: Set Out in Coop
You’re all done! Set the base on a level floor and push bedding around it. Then plug in to an electric source and set the chicken waterer on top.
Hint: If the base will not lie flat because of the extension cord, try chiseling a channel in the bottom of the wood for the cord, or prop up with scrap wood or shims.
This setup works great down to -10°F. If needed, you can always increase the heat with a higher watt lightbulb.
Also, I installed a dimmer switch on my coop’s electric source so I can better control the amount of heat and not waste electricity.
20 Comments
rondame 4 years ago
TheGrovestead 3 years ago
Errol1951 4 years ago
YoramG 4 years ago
OculumForamen 4 years ago
yeagerxp 4 years ago
YoramG 4 years ago
thansen871 4 years ago
charlessenf-gm 4 years ago
There's a significant difference as between little fishes and the fowl he's attempting to provide Winter water for! Chickens are very active! Violently so at times. They have been known to upset, knock over, break feeding devices, heating lamps, watering devices, etc.
Thus a Bullet Proof Aquarium Heater might suffice - but the electrical wiring in close proximity to fowl that do not understand basic electrical codes presents a clear and present fire hazard as well as electrical (deadly to chickens) shock.
Best to keep all the wiring outside their environment and, when possible, out of 'reach!'
Penolopy Bulnick 4 years ago
KarenP177 4 years ago
OldBlackBelt 4 years ago
However, your idea is shear simplicity. If you added a thermal outlet (Farm Innovators TC-3) that kicks on at less than 35 deg. and off at 45 deg., you would have basically the same thing at a lot less cost. And we put our waterer up on bricks to keep it out of the dirt. So if you put a 12" x 12" paving stone under it I don't think the hens could tip it.
IamTedV 4 years ago
Take an old drip coffee maker apart and find a thermo-switch that will cut the power to the heating element if things get too hot (kindling temp of coop shavings?) in the can it is fixed to. Come to think of it, you can scavenge a heating element from such a thrift store find and eliminate the porcelain fixture and bulb.
When those cheap electric griddles go on sale next Black Friday ($8 after Rebate!!!) replace your old worn/scratched one and you have an aluminium heating element that as a thermostat allowing a range of temps that could be used UNDER THE COOP FLOOR (exposed to open air all-round*) in conjunction with the Temp Controlled outlet first referenced above:
https://www.amazon.com/HEATIT-Freeze-Thermostatica...
* I've used this approach w/o the thermo-controlled outlet as it warms the coop and the watering device as well - heat rises
SylvanB 4 years ago
Those nipples are installed in 5gal buckets, 2 or more per bucket.
The water is warmed in each bucket with a small stock tank heater (with anti-melt guard to protect the bucket).
shalnachywyt 4 years ago
