Introduction: DIY 600 Watt Amplifier With Old Computer SMPS
Hey! everyone My name is Steve .
Today i'm going to show you How to make a 600 watt amplifier With Computer Power Supply
Let's Start
Step 1: Make Your PCB
This post is supported by NEXTPCB.
I’ve been really impressed with the quality and consistency of their work. NEXTPCB offers professional PCB fabrication and assembly services, making it easy to bring custom electronics projects to life — whether you're prototyping or doing full production. Their support team is helpful, turnaround times are fast, and the results speak for themselves. If you're looking for a reliable partner for your PCB needs, I genuinely recommend checking out NEXTPCB.
Step 2: Features
Power Output
- 600 watt x 1 mono
Power Input
- 48V 10A DC
Input & Output
- RCA input
- Speakon Output
Features
- Thermal cool down @ 50 degree Centigrade ( Fan kicked up )
- Short Circuit Protection
- Overheat Protection
- Overload Protection
- Revers Polarty Protection
- Low Pass Filter Built In
- Very Low distortion
- PurePath™ HD Technology
- Class D technology
Step 3: Stuff I Used
Where To Buy "Cheapest"
- Tube Pre-Amplifier - https://goo.gl/TZV42W "10% off for Electronics:Elec"
Aliexpress
- 600 Watt Amplifier Board ( TAS5630 ) - https://goo.gl/A3VttF
- Temperature Switch (W1209) - https://goo.gl/A3VttF
- 48V Power Supply - https://goo.gl/A3VttF
- XT60 Connector - https://goo.gl/A3VttF
- Speakon Connector Female - https://goo.gl/A3VttF
- Speakon Connector Male - https://goo.gl/A3VttF
- RCA Socket - https://goo.gl/A3VttF
- Volume Knob - https://goo.gl/A3VttF
- Carbon Fiber Vinyl - https://goo.gl/A3VttF
Amazon
- 600 Watt Amplifier Board ( TAS5630 ) - http://amzn.to/2p431mF
- Temperature Switch (W1209) - http://amzn.to/2plyDop
- 48V Power Supply - http://amzn.to/2plyDop
- XT60 Connector - http://amzn.to/2plyDop
- Speakon Connector Female - http://amzn.to/2plyDop
- Speakon Connector Male - http://amzn.to/2plyDop
- RCA Socket - http://amzn.to/2plyDop
- Volume Knob - http://amzn.to/2plyDop
- Carbon Fiber Vinyl - http://amzn.to/2plyDop
Banggood
- Temperature Switch (W1209) - https://goo.gl/P0EyYO
- 48V Power Supply - https://goo.gl/P0EyYO
- XT60 Connector - https://goo.gl/P0EyYO
- Speakon Connector Male - https://goo.gl/P0EyYO
- RCA Socket - https://goo.gl/P0EyYO
- Volume Knob - https://goo.gl/P0EyYO
- Carbon Fiber Vinyl - https://goo.gl/P0EyYO
https://www.utsource.net/ is an online platform for electronic technicians, Makers, Enthusiasts, Kids to find electronic components
Step 4: Opening
- First of all i used a screw driver to unscrew the 4 screw on the SMPS
- And then i opened the SMPS
- and again i unscrew the main PCB board and removed it "See the image "
- and then i unscrew the power input socket
- and then i unscrew the fan
- and then i cleaned it with some old cloth
Step 5: Drilling
- I drilled 4 holes to mount the Main amplifier board " you have to figure that out "
- I drilled 1 small hole for speakon connector and i used a step drill bit to match the Speakon Dimension
- And then i drilled 2 small holes for RCA input and then i used a step drill bit to match the RCA Dimension
- And then i drilled a small hole for volume port and used a step drill bit to match the port dimension
- And then i took a Copper Clad to cover the power input hole and did some hole to match the port dimension "See the Image "
Step 6: Giving It Some Look
- I used Carbon Fiber Vinyl Red & Black to give it such look
- First i cover the Copper clad with red vinyl
- and Secondly i cover the SMPS Body
- Don't Forget to cut out the air vents
Step 7: Installation
- Firstly i stick the copper clad with some super glue
- and then i installed volume port to the copper clad
- and then i installed the fan
- and then i installed the Speakon Connector
- and then i installed the RCA input Socket
Step 8: Connections
- I Soldered some stereo wire to the RCA input
- and then i used a female header to soldered the end
- and then i used 2 wire to solder the speaker output on the Amplifier Board
- and then again i used 2 wire to Solder the Power Input on the Amplifier Board
- and then i used 4 screw to screw the main amplifier board to the SMPS box
- and then i used ribbon wire to connect the Amplifier board to volume control board
- and then i soldered the 2 speaker output wire coming from the amplifier board to Speakon Connector and used a heat-shrink tube to secure the connection
- and then i connected XT60 connector to the power input wire coming from the amplifier
- and i used some hot glue to stick the XT60 to the box " See the Image "
- and then i connected female header coming from RCA input wire to the Volume control board
Step 9: Fan Controller
- I used a temperature controlled switch for turning on the fan at 50 degree Celsius
- I soldered 2 wire on the amplifier board " the amplifier converts 48v to 12v dc for the fan "
- and then i connected 2 wire to the control board
- and then i connected fan wire to the control board
- and then i used dual sided tape to hold the board to the SMPS box " See the Image"
- and then i connected temperature sensor to the control board
- and then i powered the whole thing up with a 48V 10A power supply
- and then i set the trigger temperature
- and then i used some silicone glue to stick the sensor to heat-sink
- and then i used 2 led and a resistance in series and connected to the 12v rail
Set the Temperature
- tap to set button
- tap to "+" and "-" to set the temperature
- tap set button to save the settings
Step 10: Finishing
Close the SMPS box and screw the 4 screw
Click Here to See The Video
You Just Made It
Now just Plug the power and enjoy
Thank you for visiting my Instructables Stay tuned for next Projects
