DIY AVR Microcontroller Based Temperature Monitoring and Control System
Intro: DIY AVR Microcontroller Based Temperature Monitoring and Control System
For more Stuff Visit Steps2make.com
AVR Microcontroller based Temperature Controller, it uses LM35 Temperature Sensor for measurement of temperature and 16x2 LCD is used to display temperature set point, Heater Status and current temperature, It controls temperature by turning on and off of the heater using relay.
This project is very useful for controlling of temperature, It can be used for soldering station to make it automatic temperature controlled. In this project two switches are used for setting the set points. You can try this project using Protius simulation. Circuit diagram, Layout is provided with code. Download respective files.
STEP 1: Components Required
1. Atmega 8 Microcontroller
2. LM35 Temprature Sensor
3. 12V Relay
4. 16x2 LCD
5. BC548
6. 1K Ohm Resistors
7. Tectile Switches
STEP 2: Circuit Design and PCB Manufacturing
Download Requires Files Click Here Link to Download
1. Try Simulation Download Protius Simulation File
STEP 3: Programming the Controller
Download Hex File or AVR Studio Code From Here
Test Your Project
Karavan 7 years ago
Link to code not working.
