Introduction: DIY | Adjustable Timer Using 555 & Potentiometer
DIY | Adjustable Timer using 555 & potentiometer
Step 1:
Step 2: Making Video
You can watch the making of the video by the clicking the video linked in this step or continue reading to make your own timer
You Can Subscribe To My YouTube Channel By Clicking HERE
Step 3: Components Required
1. Push Button
2. 555 Timer IC
3. Red & Green Led
4. 100uF / 25 volt capacitor
5. 0.01uF capacitor
6. 2.2 Mega Ohm resistor
7. 10k Ohm Resistor
8. 330 Ohm Resistor
9. 220 Ohm Resistor
10 470k Ohm Potentiometer
11. 3 Pin PCB male & Female connector
12. PCB Board
13. Wires
14 Battery & Battery Cap
15 Hot Glue Gun
16 Insulation Tape
Step 4: Circuit Diagram
In my design i have used RED LED for output, But if you need real practical application i would suggest adding a
5 volt relay or a 5 volt buzzer so that it can perform some other operation once achieving the time.
Step 5: Construction
Mount & connect all the components as per the circuit diagram.
Note :
1. as mentioned in the previous step in the image 3 i have used RED LED for output, But if you need real practical application i would suggest adding a 5 volt relay or a 5 volt buzzer so that it can perform some other operation once achieving the time.
2. I have used 3 pin connector & attached it to 470k potentiometer as shown in the image 5. The reason for doing this is, so i can change the potentiometer for different timing. Using 470k pot i would achieve time range between 5 to 10 minute. To achieve lower time range using lower potentiometer will help.
3. to achieve higher time range you need to increase the value of the electrolytic capacitor which is connected to the pin 6 of the 555 timer (shown in the image 4)
4. This circuit achieves only a approximate value. To achieve a exact timer i would recommend using programmable or micro controller based timer(ex: Arduino)
Step 6: Finished Images
1st Image - Finished Board
2nd Image - Timer Running
3rd Image - Output
To watch the real time testing pleaseCLICK HERE
Testing begins @ 2 minute mark
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : http://goo.gl/gKjns4
Amazon US :
555 Timer - http://amzn.to/2az9Y96
470k Pot : http://amzn.to/2aldcMV
Push Button : http://amzn.to/2a8NbNp
Resistors, Capacitors & Others Things : http://amzn.to/2a2CzU8
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
PCB Board - http://amzn.to/2abRXw7
Insulation Tape - http://amzn.to/29YNZax
Hot Glue Gun - http://amzn.to/29Y2BU8
Amazon IND :
555 Timer : http://amzn.to/2a3UYR7
470k Pot : http://amzn.to/2aOz3KQ
Capacitors, Resistors & Other items - http://amzn.to/29GbUwT
LED - http://amzn.to/29Gd7nW
Push Button : http://amzn.to/2a3VhLP
Hot Glue Gun - http://amzn.to/29HEslT
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
PCB Board - http://amzn.to/29Ged2O
Insulation Tape - http://amzn.to/29HGzpJ
PCB Board Connectors - http://amzn.to/29P6wU4
Please subscribe to my :
You Tube Channel : https://goo.gl/ctc8l9
