Introduction: DIY Amazon Echo
Amazon Echo is now becoming a trend in the space of home automation and voice personal assistant. The ability to link the echo with other devices like philips hue, Wemo light switch etc... have made them more robust and flexible.
In this project, I am going to make a custom Amazon echo using the raspberry pi. The support for the alexa is provided by Amazon developer account. Also I will be making a custom case for the entire project to en-cooperate all components in to a single unit..
So let's get started...... !
Step 1: Gathering the Materials
1. Screws, nuts and bolts
2. Cardboard sheet for enclosure
3. Speaker
4. 220 v AC - 9 v DC circuit
5. Audio amplifier circuit (you can also use PAM8403)
6. Wooden box frame (for the enclosure)
7. Raspberry pi 2 (Installed with raspbian)
8. USB sound card with Mic
9. Wifi Dongle (not required for raspberry pi 3)
NOTE:>> speaker,amplifier circuit and voltage converter can be salvaged from an old PC speaker
>> Installation of raspbian can be found here
Step 2: Polishing the Enclosure
Polishing helps to make the finished project aesthetically appealing. I've used normal wood varnish to coat the box.
- Sand the surface using a 60 grid sand paper and clean up all the dust
- Apply a coat of the varnish using a cotton cloth
- Let the box dry
- Apply another layer of varnish to give a glossy finish
Step 3: Preparing the Enclosure
- Cut the cardboard for the wooden box as per required size (X2)
- Drill holes on front side cardboard for speaker vents (I've used 6mm bit)
- Drill holes at back side cardboard for the control knobs for the speaker
- Paste cloth mesh at front side from inside for the speaker vents
Step 4: Setting Up Amazon Developer Account
Register for an Amazon Developer Account :
1. Signup for an amazon developer account
2. Login to Amazon developer account
3. Click on the "Alexa" tab
4. Click "get started" on the Alexa voice service
5. Select Register a product > Device
6. Name your device ID and display name and click next
7. On the Security Profile screen, click “Create new profile”
8.Under the General tab, next to Security Profile Name name your profile. Do the same for the description then click Next
9. Make a note of the Product ID (from device type info), Client ID, and Client Secret generated
10. Click the Web Settings tab, then click the Edit button next to the profile dropdown list
11. Next to Allowed Origins click, Add Another and enter the following:
https://localhost:3000
12. Next to Allowed Return URL's click, Add Another and enter the following:
https://localhost:3000/authresponse
13. Click next
14. Fill in the device details tab as per your requirement like image, description etc...
15. Submit the information.
Now you have succesfully created the account for alexa voice service !
Step 5: Setting Up Raspberry Pi
After installation of Raspbian follow the steps:
1. Connect the usb sound card with mic, Wifi dongle, keyboard and mouse to the pi
2. Open the terminal and type :
cd Desktop
3. Type in git clone
<a href="https://github.com/alexa/alexa-avs-sample-app.git" rel="nofollow">https://github.com/alexa/alexa-avs-sample-app.git...</a>
and press Enter.
4. Then type
cd ~/Desktop/alexa-avs-sample-app
and press Enter.
5. Type
nano automated_install.sh
Press enter
6. Type in the ProductID, ClientID, and ClientSecret that you notes in the step above in the editor which opened up and press CTRL+x to save the file.
7. Then type in
and press Enter.
8. Then type
. automated_install.sh
and press enter
9. Several questions will be asked during the installation reply with Y/N according to the questions. This may take some time (about 30 min.). So take a break....
Once these steps are done its time to start alexa service described in the next step
Step 6: Running Alexa Web Service on Pi
Open three terminals for each of the following main steps:
TERMINAL 1
1. Type in
cd ~/Desktop/alexa-avs-sample-app/samples
and press Enter
2. Type in
cd companionService && npm start
and press Enter.
This starts the companion app and opens up the port to communicate with amazon.
TERMINAL 2
1. Type in
and press Enter
2. Type in
cd javaclient && mvn exec:exec
and press Enter
3. Click yes for the authentication window poping up.
4. This opens up a browser window. A second pop-up will appear in the Java app asking you to click Ok. Do not click this yet.Log into your Amazon account in the browser.You’ll see an authentication screen for your device. Click Okay. Your browser will now display “device tokens ready.”You can now Click the Ok pop-up in the Java app.
5. Now the raspberry pi is able to communicate with amazon alexa server
TERMINAL 3
1. Type in
and press Enter.
2. Type in
cd wakeWordAgent/src && ./wakeWordAgent -e kitt_ai
3. Now your raspberry is listening to you for wake word "Alexa"
Test out the Alexa by saying wake word "ALEXA" followed by the question like "Whats the time" If every thing is properly configured you will be replied by the answer by alexa through the speaker.
NOTE: connect the speaker to 3.5mm analog port and set it as default audio output. Find more at here
For any clarification see the GIF file attached with this step
Step 7: Putting Every Thing Toghether
The last step is to put every thing into the enclosure:
1. Mount the Speaker to front side cardboard with nut and bolt.
2. Mount control knob, adapter to the enclosure
3. Connect Raspberry pi to the Aux cable and provide a micro USB cable to power it.
4. Close the enclosure with back side cardboard
Step 8: Finishing It Up !
1. Connect the power for speaker and Raspberry pi to the socket
2. The raspberry pi will boot up and use either SSH or monitor to perform steps defined in step 6 to start the alexa web service
That's it now you have developed your own alexa personal assistant. If needed you can create a script to automatically start the alexa web service.
I hope u all liked the project... Thank you...! :)
