DIY Anaerobic Chamber (aka Glove Box)
Intro: DIY Anaerobic Chamber (aka Glove Box)
This DIY Anaerobic chamber is considered a fully functional piece of Bio Art, As a statement from the Maker DIY community to the large Institutions that have a tendency to withhold knowledge. It was designed and built to grow cultures of Geobacter Sulfurreducens bacteria, to do research and experimentation on my other Bio Art project: a Microbial Fuel Cell project called "BactElecTric".
It is important to state the fact that this is piece of equipment intended to be used in a Bio Safety Level 1 lab environment.
Also, it was conceived to keep a low oxygen level atmosphere inside of the chamber, it is constantly pumped with inert gas such as Nitrogen or Argon.
It is NOT(repeat...not) intended to keep organisms from going outside of the chamber, it is intended to keep a desired atmosphere inside, with positive pressure.
It is NOT air tight, the positive pressure and small leaks keeps outside air from going in.
This is a functional piece of biology lab equipment, it was welcomed inside GENSPACE, the first community Biolab, based in Brooklyn, New York.
STEP 1: Chamber Parts Breakdown
1- Big plastic container (36 gal), as clear as possible, as big and square as you can find.
2- Gas intake
3- Relief valve
4- Double hatch system (two plastic food containers)
5- Double gasket with metal reinforcements
6- Pressure gauge
7- Rubber arms (flex tube) and gloves
8- C clamps
9- Insulation foam + silicon + duct tape
More detailed material list and building procedures ahead.
STEP 2: Materials Used
STEP 3: Footers
I suggest using half inch screws.
I used 1/16 inch rubber to make small gaskets, reinforced with Lexel.
(!!!note on the Lexel: It takes very....very long to dry (curate), bu is is 1000x better than silicon!!!)
STEP 4: Closing the Lid
The corners are a little tricky but with patience and a good x-acto knife, the insulating foam works.
You can use as many C-clamps as needed.
The idea is to NOT close the lid permanently, so that the chamber can be opened for cleaning, maintenance, modifications or any other need, without loosing integrity.
(You can also get a big sheet of 1/8" rubber and tailor a nice big gasket...)
STEP 5: In Goes the Gas
I used quick release valves so that you could change hose, or gas type without compromising the integrity of the chamber and to be able to be stand alone in case the hose (or gas tank) needs to be removed or exchanged.
On the inside of the chamber, the valve has a brass connector to screw a barb to connect a hose (you can find size adapters), this is if you need to sparge (blow bubbles) a liquid medium (as it was my case) with a certain gas.
I used a power drill, starting with a small diameter bit, incrementing the size bit by bit. It is important that you insert the drill while its moving at high speed (do not start the drill while touching the plastic). I also used fabric tape to help support the plastic.
Remember to clamp a piece of wood on the inside and the whole chamber to a corner of a table, so that you can drill properly.
!!!!!RECOMMENDED:
Latter on I used the Dremel, using a pointy polishing stone to make the first hole, and then, using the Dremel and a sanding paper tip, to make the whole to the desired size.
To help seal the hole properly and make it air tight, I used a gromit.
finally, I caulked some Lexel around the brass valves, inside and outside. (remember to let it dry for a very long time)
!!!!! IMPORTANT !!!!!
To prepare your oxygen free (almost) atmospherey
To sequestrate the oxygen of the normal atmosphere, I used "food preserving tablets" they are used to preserve dry food for extended periods of time.
I got them on line and you can easily calculate how many you need for your chamber size. I just put them in a corner of the chamber in a way that they did not interrupt my work... and later on i got them out of the chamber through the double hatch mechanism.
STEP 6: Just in Case, Pressure Relief Valve
As mentioned before, this time I used a Dremel to make the hole. I recommend this technique over the power drill, to work with plastic containers.
The same finishing touches of the gas intake valve where made to this pressure relief valve.
I decided to put both valves on the same corner of the chamber, so that I would not have another corner used up and could not place elements in it.
STEP 7: Accordion Arms
Funny thing is... they worked!!!
Make sure you make a prototype of your arm size and distance between arm holes, before you get to work on the chamber.
Also, be sure to use enough accordion tubing, to reach the inside of the double hatch while you are working.
The best way to make the big holes for the arms is with the Dremel, as explained before. (not a plastic cutter as I first did)
Since the accordion tube, had a spiral structure, it did not seal very nicely against the edges of the holes on the plastic wall of the container. To deal with this, i used expanding sealing foam... and a lot of Lexel.
It worked ;)
STEP 8: Rubber Gloves
Because of the spiral structure of the accordion tube, A LOT of patience and time was needed to seal the union of the gloves and the accordion hose. I cut and tailored pieces of gorilla tape independently as I worked, so that they made a "scale mail" pattern, like scales on a fish of armor.
Additional support was provided by zip ties...and the gloves own rubber.
This elements have been optimized with liquid rubber spray, to strengthen their structure.
During lab work, it is strongly advised that you use your lab gloves while using the chamber, your hands sweat a lot, and getting them out of the chamber's gloves can be tricky.
STEP 9: Double Hatch Ensemble
This dual hatch system was designed so that minimize loss of atmosphere while working, and provide a way to get elements needed into and out of the chamber at any given time. (without having to open the whole chamber and loosing all your atmosphere)
Be very careful making your holes. For this I made templates made of masonite, so that every hole drilled was on the same spot.
You'll see on the next step, this is very important to make the dual gasket system for the dual hatches.
STEP 10: Hatch Gaskets
The wholes on the metal frames where drilled with a Drill Press. The metal frames where made so that screws could be used to really tight the sandwich of layers that this step dealt with, without compromising the integrity of the plastic containers. In other words, this was done so that the plastic didn't crack when you tight the screws as it is needed for the air tight sealing of this large square hole on the chamber.
Everything was done using the same templates that where made at the beginning of the double hatch process.
For everything to come together correctly, you have to use clamps, to make all the layers be tight and pressed against each other.
layers (in order of appearance):
metal, plastic container 1, rubber, plastic wall of main chamber, rubber, plastic container 2, metal
The finishing touch was to caulk Lexel on the outside edge, and Silicon on the inside. I only used silicon because the caulking gun was too big to be used on the inside of the chamber
If you can TIG weld your metal frame so that it is one solid piece, it is best, I want to do it for my next chamber :)
STEP 11: Horiozontal Surface for the Hatch
Since the walls of the main chamber are tapered, the double hatch is inclined downward towards the inside of the chamber. There is also prominent edges because of the gaskets.
I did the pieces with plexi, on a laser cutter, but they can be made by hand. They three pieces were glued using "weld-on" and the notches on the middle were made,by hand, very carefully, with the Dremel.
STEP 12: Pressure Gauge
The finishing touch was made with silicon...inside and outside
The only comment is that I want to replace this gauge with another one with a smaller scale, up to a 100 is enough.
The pressure relief valve works at 70 psi.
46 Comments
johnyradio 5 years ago
LizZ5 7 years ago
Thanks for the hot tip about the rubber gloves. Really saved the day when our anaerobic chamber started leaking through it's degraded cuffs.
I noticed you don't have an oxygen sensor per say, did you know you can make a solution of reduced methylene blue that will turn blue in the presence of oxygen. I think you can also purchase strips to act as indicators.
VictorA205 5 years ago
hI LIzz is only methylene solution? or we need to add more reagents?. I saw a combination with glucose
rolonrene 7 years ago
Hi,
I am not very sure about how to manage nitrogen or argon, so my question is: are all the valves you used especially made for the use of this types of gases? Is it dangerous to use solenoids valves?
frix00 9 years ago
Hi,
Just to confirm, you are not using any vacuum at all here ? The only way to get the oxygen level down is to pump in inert gas right ?
Did you use an oxygen detector at all ? Do you know what levels can be reached in terms of % ?
Thanks
ponckk 9 years ago
Thank you for your message, interest and support :)
Sorry for the delay.
So...
No vacuum at all.
only pumping inert gas ( the chamber is not air tight, it has some leakage, so it is actually good because you create a positive pressure situation and no outside air comes in.
using O2 sequestrating tablets (used to preserve food), and eve a small candle...to burn O2, but his is kind of risky.
Sadly I have no O2 detection... this is the big weakness of my effort.
Thank yo for your interest.
May I have more info on your project? and if you go an build one of these, could you please send me some documentation :D
I would love to se it replicated.
Best wishes
Nelson Ramon
frix00 9 years ago
Thanks for the reply :-)
We've done a very very similar project, without the box on the side to act as a intermediate chamber, but using an O2 detector :
http://www.amazon.co.uk/SPD201-Oxygen-Detector-Tester-Deterctor/dp/B00I6AOV8I/
We can get down to less tha 1% oxygen, and with a good seal everywhere, we manage to maintain that level for several days without using much of a positive pressure inside.
I've attached a couple of photos too :-)
We're currently refining it further, building it with perspex (plexiglass) which we weld together using a a solvent, and then replication professional lab glove ports, but cutting the cost using 3D printing. Will share some photos of that once we're done.
Thanks for the inspiration !
CowGuy 9 years ago
Hello, any progress with the perspex? I'd like to fabricate my own chamber
frix00 9 years ago
Hi,
We're building this at the moment, to do some re-bottling of food products, that need extremely low levels of oxygen in order to avoid oxydation.
I just wanted to clarify something: how do you reach low levels of oxygen ? Is it purely the use of oxygen scavengers and pumping inert gas ? Do you use a vacuum pump at all at any point ?
Do you have an idea of the levels of oxygen you can reach (in %) ?
Many thanks- impressive effort!
frix00 9 years ago
Hi,
adamvan2000 10 years ago
Do you have any suggestions for keeping the viewing panel I'd have to add clear from the overspray? I was thinking some sort of clear panel sandwich with small holes in the inside facing layer that I could hook up to an air pump to blow into the chamber. I can either make something like that, or see if there's something available that would do the trick.
Also, now that I think of it, I could also make one for sandblasting too, or make a single multi-purpose box.
Thanks!
ponckk 10 years ago
:D
mikeyc.2009 10 years ago
andrae cameron 10 years ago
Andrae
danbemp 11 years ago
ponckk 11 years ago
ponckk 11 years ago
rangefinder 11 years ago
Do I "really" need an anaerobic chamber ?
mattbeowulf 11 years ago
If you don't know what you'd do with an anaerobic chamber, well... maybe you ought to start doing some cooler stuff ^_^
