Introduction: DIY Arduino Robotic Arm , Step by Step
These tutorial is teach you how to build a Robot Arm by yourself
Step 1: Cutting Piece That Hold the Servo
- cutting the first piece : 6cm width , 10cm Height using mini dremel .
- use hot air gun to flex the plastic .
- cut about 1 cm from each side to put the servo inside the first piece .
Step 2: Install the Servo With Screws Inside the Plastic Piece
- Make four holes in the piece of plastic for the screws .
- Place the motor and install it with screws
Step 3: Making the U Plastic Piece
- cutting 2 piece : 6cm width , 10cm Height using mini dremel .
- Attach it with the first piece with screw ,
Step 4: Put the Servo Horn and Screw It
Step 5: Attach the First Piece We Have Made With a Piece of Plastic
Step 6: Getting Everything Together
Step 7: Coding
Step 8: Circuit Schematic
Circuit Chamtic
Includes Fritzing file
Step 9: Testing
Test the Robot Arm
