Introduction: DIY Audio Reactive LED Matrix
Did you ever felt the need for a cool RGB matrix with audio reaction feature, but found it very difficult to make or very expensive to purchase? Well, now your wait is over. You can have a cool Audio Reactive RGB LED matrix in your room.
This Instructable guides you through the easiest steps to make a DIY RGB LED Matrix with cool effects & audio-reactive feature. So, let's get started.
Follow us if you like this instructable.
Step 1: Step 1 : What Will You Need?
All the material mentioned here is easily available in your local market as well as online stores.
- Cardboard Sheet
- Masking Tape
- Maixduino Controller Board
- WS2812b Addressable LED Strip
- 18 AWG Hookup Wire
- Jumper Cables
- Female DC Power Jack
- DC adapter 5 volt 10A (Optimal current required for full white is 9A)
Note: You will require all the accessories mentioned here. You can try out alternatives for any accessory as per your convenience except the Maixduino Board.
Step 2: Step 2: Cutting & Marking the Cardboard
First, you need to cut your cardboard sheet in the size of 12 x 12 inches. This size is perfect for the LEDs as well as your room space.
Then you need to mark 10 points/holes on your cardboard with a pen/pencil/marker on top & bottom points to make guide markers for LED strip & holes for the wires. You can place the LED strip on cardboard & mark on 1st LED & 15th LED (Follow the second image).
Step 3: Step 3: Cutting & Sticking the LED Strip
Next step is to cut the LED Strip in 10 pieces. Each piece should be 15 Pixels/LEDs long.
Then stick the pieces on the cardboard with some adhesive glue. (Refer to the image)
Step 4: Step 4: Making the Connections
There are few connections only, viz;
Refer to the connections from the circuit image.
- Connect GND/0V of each LED strip piece together
- Connect VCC/+5V of each LED strip piece together
- Connect Data Out of 15th LED in each strip piece to the Data In of 1st LED in the next strip.
- Connect two wires for each Positive & Negative Connection & one wire for Data In of 1st LED of 1st strip.
- At last, connect a Female DC jack to one pair of Positive & Negative wire for power injection.
- Connect the Data In wire to Maixduino Pin #24 ( #24 is the digital pin 5 of Maixduino )
- Connect another pair of Positive & Negative wire to Maixduino Vcc & GND.
General Precautionary Measures(Optional):
- Stick masking tape on the backside of the cardboard to secure the connection wires. (Image 3).
- Use a plastic tie to secure the input wires (Image 4).
Note: Double Check the connections before powering up the device.
Correction: The LED strip in the circuit image is 10 LED long, Please Consider it to be 15 LED long. Thanks for your cooperation.
Step 5: Step 5: Let's Code It
Open the code attached with this step in the compiler & burn it in Maixduino.
