Introduction: DIY Baby Groot Planter
Hi All,
In this instructable, I will share how to paint 3d printed baby groot planter, using acrylic paints and will use 3d printed layer line to our advantage.
Hope you like it
Step 1: What Do We Need ?
- 3d printed baby groot planter
- Acrylic paints
- 0.5 inch thick brush
- Very thin brush
- White sheet of paper
- White ink marker
- Varnish spray for acrylic
Step 2: 3d Print
- You can search and download a suitable model from Thingiverse
- I used "baby groot pot (re-remix) by aricard" link https://www.thingiverse.com/thing:3357065
- My printer settings were as below
- Slicer: Cura 4.8
- Resolution: 0.28
- Infill: 10%
- Supports : Tree, everywhere, angle 60°
- Filament: black PLA
- Printing time: 14 hrs
- Scale : 150% ( height 15cm)
Step 3: Base Color
- If the 3d printed Groot is not black, then we must first paint it with a thin black acrylic paint
- Let it dry for a day before we continue
- Take the dark brown acrylic color and spread it on a white sheet of paper as shown
- Using a plain white sheet helps us to understand what colors will look like when mixed
- Using a thick (0.5") brush, apply a very thin coat of paint on 3d printed Groot
- Before the dark brown paint dries, dry brush with some yellow
- Again use paper to thin out the paint
- Since the brown paint is wet, the yellow paint mixed with it and give a light brown wooden look
- This will highlight the raised areas as a light shade of brown
- Before we continue, we will leave this to dry for 2 to 3 hours
- I covered the eyes too, donot worry, we will fix it later
- I didn't use any primer so that I could use 3dprinter's layer as wood texture
- Don't use an excessive amount of paint, as this will fill all the texture etc
Step 4: Green Veins
- Using some green acrylic paints highlight some veins on the hands
- On it's head paint green in the cracks to green moss growth look
Step 5: Eyes
- It is easy to scrape off the acrylic paint from the eyes
- I used a toothpick to remove any paint
- As per some images on the internet, the iris is black and the sclera is red (the white part of our eye is called sclera)
- Painted sclera as a mixture of red-brown color and left the eye as black
- If you are not able to scrape the paint, use black acrylic paint on it
- To fake light reflection on the eye, use a white marker to draw the reflection
Step 6: Finishing
- Let the acrylic paint dry for at least 24 hr
- Inspect groot, if there are any areas that were missed, Paint where needed
- Apply a coat of varnish spray to protect the paint job\
- Plant a small plant and admire your work
I hope you liked the instructable, If you have any questions or suggestion, please let me know
