Introduction: DIY Bangs at Home
What you need -
scissors
hairspray/mousse
(Maybe and extra help)
Step 1: Step 1: Section Off Your Hair
First, section off the hair you want to be your bangs. Make a part above it so you know where it starts.
Step 2: Step 2: Cut
Next, take your scissors and hold them at an angle with the blade pointing up.Make sure you know how short you want your bangs to be. This is where you will start cutting. Start at the right side and snip the hair little by little. If you need to angle it down a bit or make it straight, that's perfectly ok. Make sure the hair is even or angled down, not up(mine are angled).
Step 3: Step 3: Double Check!!!
It is very important to double check to make sure it is even and that you didn't leave any hair out. I had to check mine three or four times to get it right!
Step 4: Step 4: Style and Finish
Now, you may style your new bangs how ever you wish. Once your done, use a small amount of hairspray or mousse, and you are done!
