Introduction: DIY Bench Cookies
Hello there you amazing person you! This is my Instructable on how to make your own bench cookies. What is a bench cookie you ask? Well, basically they provide a raised slip resistant platform for wood working projects. Bench cookies raise your project off the surface you are working on and hold it steady so that you can paint, stain, wax, cut, nail, screw, and glue with ease. Normally a set of these will cost around $13, but I made these for $1.07. Let's get our hands dirty!
Step 1: Gather Your Materials
Alright, so all I used was some scrap 2x4s leftover from making my workbench, some of that anti-skid material that is put in cabinets and drawers to keep things from sliding around (this is where the $1.07 comes in), Elmer's Glue All, and some paint. That's it! I'm sure that you can use other materials as you see fit. Perhaps some rubber weather stripping or stronger glue would work better.
I used just a few tools; a pen, a handsaw, clamps, and some sandpaper.
Step 2: Measure Once, Cut Twice (Or Something Like That)
So here is where I had to use my head just a bit because 2x4 does not actually measure two inches by four inches. I wanted to make prisms with square tops and bottoms, so I had to measure out every 3.5 inches. Problem solved. Next I cut out the anti-skid squares to cover my biscuits. These were cut into 3.5 inch squares.
Step 3: Painting (Or Other Make-it-look-niceification)
This step is completely optional. There is no need for any paint, stain, or whatever tickles your fancy to adorn your bench cookies, but I had some extra paint so decided to throw a few coats onto mine. There are no special tricks here, I used 100 or 150 grit sandpaper and gave them a quick sanding then I sprayed on some paint. The down side to this step is now you have to wait for the paint to dry, I'm sorry.
Step 4: Finished!
Did you make it through the wait? Yay! Unless of course you chose to skip that step in which case, Yay! Alright, all that is left for you to do is glue your anti-skid squares to the largest sides of the prisms and wait for the glue to dry. That's it. You're done. Look what you just did you amazing person you! Be proud of yourself because you can do anything.
I hope you enjoyed my simple Instructable as much as I enjoyed creating it. If you have any criticism I would love to hear it. I would also be delighted to see the cookies that you have made or the projects that have been made with their assistance.
Until next time
Oz
