DIY Bluetooth Airpods
Introduction: DIY Bluetooth Airpods
Things needed :- bluetooth module
Wire cutter
Working earphone
Soldiering iron kit
Pluckers.
Step 1: Earphones
Cut the ear body of working earphone as shown in image. And keep 2 wires (red and green) which are positive (green) and negative (red).
Step 2: Bluetooth Module
We can find the blue tooth module from neckband or a bluetooth device. It will have charging port through which we can charge and a switch to start. The image of bluetooth module i used is shown in image.
Step 3: Soldering Time....
In the bluetooth module we can see the soldered wire marked L1 (+) and L2 (-). We wil solder the 2 wires of earphone. Green in L1 (+) and red in L2 (-). And battery must be attached to its pin, if not, attach it to its respective pins.
Step 4: Finishing Time
We make it attractive by attaching all the things with a black electric tape as I did or we can also attach all of them with a transparent tape which will give it a theme of circuit body.
First Time Author Contest
Be the First to Share
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    4 Comments
    Sej_Patel
    Sej_Patel
    2 years ago
    Awesome!!
    seamster
    seamster
    2 years ago
    Thanks for sharing : )
