Introduction: DIY Board and Batten Accent Wall
Creating a show stopping accent wall doesn't have to be complicated! Here's how I made a DIY board and batten accent wall for my parents' bedroom in just a few days of work!
P.S. You can see this project in action on my YouTube video!
1 x 4 x 8′ – 10′ Primed Boards*
* Board feet will be different for each project – make sure to measure your particular project before building!
Step 1: Layout the Design
First step was to layout my design. This can be done in SketchUp, or with basic math, or with painter’s tape!
Step 2: Add Borders & Verticals
Next, I cut and attached my boards with brad nails. I started with the outer border pieces and then moved to the verticals. To help find the angles I needed for my vaulted ceilings I used an angle finder (you can see this in action in my YouTube video).
Step 3: Add Horizontals
Once the vertical pieces were attached, I cut and attached the horizontal pieces. I used spacer blocks here from leftover lumber to make sure that everything was even!
Step 4: Seal & Prep
Next, I sealed all of the edges of my boards with caulking. I also made sure to fill in the nail holes as well!
Step 5: Paint
After letting everything dry, I taped off my walls and sprayed the accent wall with my paint.
Step 6: Celebrate Your Hard Work!
That's it! You can create a beautiful accent wall in just a few days of work!
Don't forget! You can see this project in action on my YouTube video!
