Introduction: DIY Bottle Safe
Every people want a safe place to hide their important things like money,document,etc.In this Instructables,I will show you easy place to safe ,in the bottle.This safe is easy to carry,easy to make,and cheap.Let's check it out!
Step 1: Watch the Video
Step 2: What You Need
This is what you need:
-A bottle with long label
-Cutter
-Scissors
-Big bottle cap(optional)
-Glue
-Water
-Duct tape
-Sand paper
-HVS paper
-Styrofoam(optional)
-Cutter
-Scissors
-Glue
-Water
-Duct tape
-Sand paper
-HVS paper
Step 3: Step 1
Remove the label from the bottle.
Step 4: Cut the Bottle
First,Cut above part with cutter.Be careful using cutter,cutter can hurt your hand.And then flatten the cutted side with sandpaper.
Step 5: Step 3
Close the above part with bottle cap(you can use other material).Use a glue,Make sure the bottle cap close the hole tightly.
Step 6: Prepare the Safe Place
Almost Finish,let's continue!
The safe place is in the below part(picture 1).First,Fill with water(Just a little bit)(Picture 2).And then close the hole with Styrofoam(or other material)(Picture 3).
Step 7: Camouflage
Take the label(picture 1).Cut it.(picture 2).Attach to the paper to make it stronger(picture 3).Cut it again(picture 4).Attach the label to the above part(picture 5).
Step 8: Finishing
Now insert your Important things,and close it with the label.And now you're finished!
Step 9: Thank You!
Thank you so much for see my Instructable!I hope you like it! And pleaseee vote me at Hiding Places Contest. Your vote is mean so much.See you guys next time,Bye!
