Introduction: DIY Brass Ring
A brass ring that I made out of scraps in my shop
Step 1: Cut Out the Piece From Your Deaired Metal
Step 2: Drilling the Holes
Start with a 1/8 drill bit and work your way up to your desired size of the hole
Step 3: Rounding of the Edges
Use a grinder or ,your preferred method to round of the edges. Once the piece is as round as you can get it. Set it up on a lathe and use a file or a metal lathe chisel to true it up.
Step 4: Polishing
Use a fine sand paper to polish tour piece ( i started at 200 grit and worked my way up to 600 grit ) i did this on my lathe, the same set as when i trued up my piece . But you can also hand sand the ring.
Step 5:
Im sorry i didn't have any pictures for u guys. I did this as a project after school and it was my first ring i have made.
