Introduction: How to Make a Bubble Bath
I was going to make a bubble bath for the summer that seemed funny because then you have your own bubble bath in your garden
Step 1: What Do You Need
1.tape
2. Bendable PVC tube
3.PVC 3 way
4.electric air pump
5.swimpool
Step 2: Make Holes
now you are going to drill holes in the PVC tube try to do as little as possible
Step 3: Secure PVC Tubes
Well you're going to use the tape to the PVC tubes in the 3-part pvc tube you do the tube in the 3-part pvc tube and you're going to tape it to make sure there's no air
Step 4: Air Pump to Fasten
Now you are going to tap the 3-piece PVC pipe tap into the air pump make sure that the light pump is higher than the 3-part PVC pipe otherwise water runs in
Step 5: Fasten the PVC Tubes in the Pool
Now you are going to fasten the PVC tubes in the pool with tape on the side and on the bottom
Step 6: Have Fun
Add water in the swimming pool and turn on the air pump and you have your own bubble bath. Have fun!
