Introduction: DIY Budget Moxon Vise
About: Follow along as I tackle awesome projects including woodworking, metal working, tool restorations, and more! Sometimes I teach and sometimes we learn together. I hope you learn a new skill, build a new proje…
How to build a Moxon Vise (Twin Screw or Dovetail Vise) on a budget. This handy bench top accessory elevates your work, making hand cutting dovetails and other actions easier to manage. Using materials purchased at a home center, you can build this vise in a weekend.
Step 1: Supplies
2x 3/4" All Thread Rod 1' Long
4x 3/4" Washer
4x 3/4" Nut
4x 3/4" Wingnut
3x 3" Brass Slotted Screw
10ft 1' x6' 4S Popular Board (Cut into 4 2ft sections)
28" 1"x2" or 2"x2" Scrap for Clamping Surface
Step 2: Cut Material to Length
I used a handsaw for this operation.
Step 3: Glue Boards Together
Glue each pair of boards together with wood glue.
Step 4: Trim Boards to Shape
Use a saw to flush the sides and ends of the glued up panels.
Step 5: Edge Plane Each Panel
I used a hand plane to true each side and the ends of each panel.
Step 6: Drill Holes for Threaded Rod
Drill out two holes that are slightly larger than your threaded rod on each side of the vise chop. Go halfway through one side, flip, and finish out the hole form the other side for a smooth hole.
Step 7:
Use a marking knife to scribe a line around the nut that has to be mortised into the chop. Use a square to make sure it's square to the side of the chop.
Step 8: Chop Out the Mortise for the Captured Nut
Use a chisel to chop out the mortise for the nut. Test fit multiple times until nut sits flush with the top of the chop.
Step 9: Add a Chamfer on Each Side of the Front Chop
Pick which face will be the front of the vise. Add a chamfer to each side of this face. This is not only aesthetically pleasing but also gives you more clearance when sawing.
Step 10: Sand Chops
Sand all side of both chops up through at least 220 grit.
Step 11: Add Cork Facing
Adding cork to the clamping side of both chops will increase the gripping power and protect the piece being clamped. I used adhesive backed drawer liner. Just line up your face on the unrolled cork, cut, stick the the jaw face, and trim to fit. Make sure the wood is clean and dust free.
Step 12: Add a Finish
I coated all pieces with a Boiled Linseed Oil and Beeswax mix (making sure to not get any on the cork face).
Step 13: Attached Clamping Board
You be able to clamp the vise to your bench, you'll want to add a small board a little longer than your vise to act as a clamping surface. I used a piece of southern yellow pine attached with three brass screws to the back side of the rear chop. I used a hand drill to pre-drill all of the holes before attaching.
Step 14: Enjoy Your Vise
Assemble everything together and enjoy your vise. Thanks for following along.
