Introduction: DIY CABINET FROM CARDBOARD.
This charming and rustic shelf cabinet is a perfect example of how creativity can transform everyday materials into something stunning and functional. Made entirely from cardboard, this DIY piece is shaped and finished to resemble a natural plaster shelf, giving it a unique, altogether aesthetic look. Lightweight yet sturdy, this eco-friendly project brings style and sustainability into your living space.
So, today, I will show you how you can make this shelf cabinet from scratch.
- Large cardboard sheets (from old boxes)
- Cutter/utility knife
- Scissor
- Ruler and pencil
- Newspaper or old paper
- White glue
- paper tape
- Plaster of Paris (POP)
- Gloves
- Water as needed
- Polystyrene
Step 1: PLAN THE DESIGN:
- Sketch out your shelf design on paper.
- Decide on the number of compartments and their shapes (asymmetric, rounded like in the image).
- Measure and mark the final size of the whole unit.
Step 2: CREATE THE FRAME:
- Take a big carton size, as shown in the picture, and remove the front sheet of the carton.
- Sketch out your layout or shelf design on the cardboard.
- Cut strips of cardboard for the shelves. You have to cut the same measurement of cardboard strips as the side breadth of the carton.
Step 3: ASSEMBLE THE STRUCTURE:
- Attach the strips as you draw the shelves.
- Use paper tape generously to make the structure sturdy.
- Reinforce with extra layers of cardboard if needed, especially at the joint.
- Fill up the gaps between the cabinet with the help of polystyrene and newspaper.
- TIP: Fold the cardboard properly and make the structure before sticking it.
Step 4: FRONT LAYER OF CABINET:
- Take the cardboard sheet you had previously cut off from the carton.
- Draw the same layout on this cardboard sheet as well and cut out the shapes.
- Now, stick this cardboard sheet on top of the base structure with the help of paper tape.
- Secure the structure properly; otherwise, in the next step, it will be problematic.
Step 5: . PAPER AND WHITE GLUE LAYER:
- Prepare the white glue mixture (Add white glue + water in a bowl).
- Tear newspaper into squire size and dip into the paste.
- Apply paper white glue mixture layers all over the shelf structure to give it a solid, textured finish.
- Let it dry completely (this may take a day or more, depending on the thickness).
Step 6: ADD TEXTURE:
- For a more earthy or clay-like texture, mix 1 bowl of water, 2 cups of plaster of pairs, and a little amount of white glue (to make a cake batter-like consistency).
- Apply a thin layer of white glue over the dried paper white glue layer.
- Apply 2 to 3 coats for a good texture.
- Smooth out with your fingers or a spatula for an organic finish.
- Let it dry completely.
- Style and decorate cabinet with your favourite items.
TIP: While working with Plaster of Paris, you have to work quickly.
