DIY CD/DVD 5.25" Bay PC Computer Cooler
27,766
46
28
Introduction: DIY CD/DVD 5.25" Bay PC Computer Cooler
If your computer is getting too hot or if you need a better way to cool your hard drive you can peek into my project and use if for your case!
This is an 8cm fan fit into 2 of your case's original CD drive masking pannels. You can install hard drives behind the fan using 5.25" to 3.5" adapters.
Together with the freeware "speedfan" this is a great way to cool your computer on-demand (and still keep it fairly silent)
Step 1: What You Need
you'll need:
  • 2 of your case's original CD bay protectors (the ones made out of plastic)
  • one 8 cm fan or possibly two smaller ones. the bigger the fan the better the air flow and the less noise it will make for the same cooling results
  • fan screws & drill or glue
  • hard-disk power (4pin) to fan power (3-4 pin) connector (if you're not planning to drive it from the motherboard)
  • dremel tool with cutting disc
  • SAFETY GLASSES!!! high speed cutting tools can damage your eyes
  • screwdriver
  • marker
  • camera to take pictures and show off
first put the 2 CD bay protectors together and mark the fan's position on their back. this will guide your cutting.
Step 2: Get to the Cutting
start cutting on the back of the plastic along the marks.
Step 3: Add the Fan
drill the fan holes and add the fan with the screws. optionally you can use glue instead of screws. screws will however allow you to also attach a finger protector for the fan.
Step 4: Put It Into the Case
carefully put your new toy into the computer case. connect the cables (make sure you're touching the metal part of the case first to discharge any electrostatic charge you may hold!!)
Step 5: Sit Back & Enjoy
start your computer and enjoy the result!
Step 6: Get the Speedfan Control Software for Your Fans
if you chose to control your fan with the motherboard / software, download speedfan and set it up for your fan. be aware that if you dont know what you're doing you may destroy your CPU (if you stop your CPU fan for too long)
set the speed of your speedfan front fan so that it is not bothering your hearing.
in the setup you will need to select "software controlled" for the PWM that controls your fan. notice that not all connectors on your motherboard will work to control your fans. some may be "on/off" or just reading the speed of the fan and providing no speed changes whatsoever.
once you find which fan connector works for you adjust the max speed to a value that wont bother you. also check "automatically varied".
set up the warning temps which will drive your fan to 100% (read "very noisy")
return to the main window and set the "automatic fan speed".
dont forget to add speedfan to your startup group.
and you're done!
hope you enjoy your new DIY cheap but effective cooling solution :)
Be the First to Share
    • Home Cooked Speed Challenge
    • Robots Contest
      Robots Contest
    • Unusual Uses Contest
    28 Comments
    abadfart
    abadfart
    12 years ago on Introduction
    thanks i have been having an over heating problem with the computer that is distend to be my server
    xrobevansx
    xrobevansx
    14 years ago on Introduction
    1. That thing looks like it is going to take off 2. I don't care what speed controller you are using there is no way that can be "very silent" Still...I bet it cools like all get out!
    DIYSlacker
    DIYSlacker
    Reply 14 years ago on Introduction
    it is TERRIBLY LOUD without speed controller - runs at 2800 rpm - feels like its going to take off! but once i set it to 1500rpm it sounds pretty much like a PSU fan when you listen closely. i was very pleased with the result of speedfan! of course its not completely silent until you get to about 35% but that defeats the cooling purpose...
    Derin
    Derin
    Reply 12 years ago on Introduction
    My 3k rpm fan is pretty silent.
    tetleyex
    tetleyex
    I think if you use a grill like gmjhowe suggested instead of making the fingerguard yourself you will notice a large noise decrease. Unfortunately you won't get to show off your handywork with a dremel quite as much, but it should be a little closer to silent.
    http://www.cpemma.co.uk/ this guy seems to know what he's talking about "Keep the flow effective with a clean path through the case – a good case design, open wire grilles...".
    But yeh, nice instructable =].
    DIYSlacker
    DIYSlacker
    obviously there's a whole science in cooling your PC especially if you're overclocking :) but my main concern - since i'm not overclocking - was to keep my 4 drives cool and the PC relatively silent. the 92mm fan in the front of the case wasnt able to do that (after i bought my last 2 drives) and the store bought "startech" hard drive fan (which you see on top of my fan in the picture) was too noisy so i took it back. now i've mounted only 2 drives in the drive bays behind the 92mm and the other 2 behind this baby and they're cooled really well with the 80mm fan speeds of 800-1200rpm. my data is more important than the other computer parts - although thanks to this the whole PC is now a few degrees cooler.
    Derin
    Derin
    Reply 13 years ago on Introduction
    SPEEDFAN SHOWS MY CPU TEMP AS A FLAME!!!!EVEN WITH NO SIDE COVER!
    firestormcomputers
    firestormcomputers
    being without a side cover isnt really that good of an idea especially if foreign matter gets in there just pop some fans in your case on stress points and turn the fan accordingly to how the airflow should be directed hope this helps
    Ex Marine
    Ex Marine
    Do you "NEED" the soft ware or can you leave it as it is
    ReCreate
    ReCreate
    leave it as is you don't NEED it it just would be more convenient
    ReCreate
    ReCreate
    speed fan doesn't work for me its probably because i have no fans the only fan in my computer in the cpu fan but it doesn't appear in the program
    strmrnnr
    strmrnnr
    How do you find it as a heat source. The extra heat from your PC is used to heat your room. Right now the temp is -20C outside. It helps a lot here. Thanks.
    DIYSlacker
    DIYSlacker
    obviously lots of the energy used by a PC is transformed into heat. this fan (in use for over a year now) helps that heat get into your room where it's useful during winter instead of overheating your drives or cards. helps with your heating bills and data safety ;)
    lucek
    lucek
    I have a thermaltake with a filtered mesh fount panel and I was thinking about doing something like this with the 3 extra cd ports. i already modded the passive vent for the gpu with a fan and it has one for cpu cooling. so I'm thinking that it may be overkill with 2 90 mil fans 2 120 mil fans and another 120 mil on the psu
    Yerboogieman
    Yerboogieman
    thats an idea, i bought a new fan and my dad said it was kool, but i cant see it
    uncle frogy
    uncle frogy
    As it happens I have just finished some cooling/noise moding. I got a computer from a friend that was very fully packed and had 9 fans in it sounded like a dust buster battery vac. the main source of the noise was the CPU fan had a aluminum grill over it that was flat the fan blades were next to it and they made noise when I removed the "grill" Db's dropped in half I have since changed to a cheaper and quieter (21dba) CPU cooler now I can stand to be in the same room. I would suggest replacing the "grill work" with a piece of window screen held in place by the fan and screws as a way to reduce the noise level. something to keep it from sucking bugs in. keep it up I will use this idea for sure.
    DIYSlacker
    DIYSlacker
    yes i thought of cutting it completely and i am aware that anything in front of a fan increases the noise (exponentially?) but it looks cool with the blue light and i'm too lazy to do it now :) for anyone building a budget HTPC that needs to be as silent as possible - this is good advice though.
    gmjhowe
    gmjhowe
    i like it, good instructable, and a great idea, only thing is, i would of been tempted to drill a circular hole, using one of the tools thingys, and then attaching a nice grill. because like u, im too great with a dremal
    DIYSlacker
    DIYSlacker
    i thought of a circular hole initially but then i realized it would be much more fun to make a pattern. plus i saved 2 bucks for the finger guard ;)
    gmjhowe
    gmjhowe
    hey, who needs finger guards???? it less fun that way
