Introduction: DIY Calendar
Hi guys! In this post I'll be showing you how I made this calendar. This calendar is a cute room decoration and can be used every day. This craft isn't too difficult but does take a bit of time. It also isn't very expensive considering most of the supplies can be found in your own house. I hope you enjoy!
- Card Board
- Small Nails
- Hot Glue Gun
- Spray Paint
- Card Stock
- Scissors
- Hole Puncher
- Pencil
- Ruler
- Markers
Step 1: Make Board
- I cut out two square pieces of card board. One was 12 inches by 6 inches and the other was 12 inches by 2 inches.
- After cutting out the pieces I hot glued the larger piece vertically on top of the smaller piece.
- Then I spray painted the glued pieces gold and let it dry.
- After it was dried, I nailed three nails evenly across the top of the card board.
- To finish it, I put hot glue on the backs of the nails so that the nails wouldn't come loose or be pokey.
Step 2: Make Months
- To start, I cut out 12 3 inch by 5 inch squares of card stock.
- After I cut out the 12 pieces I punched a hole in the top center of all of them.
- Then I wrote out the month and a correlating picture on each slip of paper in pencil.
- After I had it all written in pencil, I went back in with black and colored markers to make it look more finished and professional.
Step 3: Make First Digit
- To start, I cut out 4 3 inch by 5 inch squares of card stock.
- After I cut out the 4 pieces I punched a hole in the top center of all of them.
- Then I wrote the numbers 0-4 on each slip of paper in pencil.
- After I had it all written in pencil, I went back in with black markers to make it look more finished and professional.
Step 4: Make Second Digit
- To start, I cut out 10 3 inch by 5 inch squares of card stock.
- After I cut out the 10 pieces I punched a hole in the top center of all of them.
- Then I wrote the numbers 0-9 on each slip of paper in pencil.
