Introduction: DIY Candy Dispenser!
Have you ever cut or open a candy bag in the wrong way and it all spilled? or are you just wanting to put your candy in something ππππ »π Έππ ·. If that's the case then look no further because you're in the right place! I introduce you to my version of a candy dispenser. If you do decide to make this i hope you enjoy making and using it as much as I did =D (this was also a school project)
Good scissors - Can be found in stores
Medium Cardboard box - Can be found in certain store items
Hard Plastic - Can be found in certain store and food items
Small Candy - Can be found in certain stores
Clear Tape - Can be found in certain stores and hardware stores
Wood Glue - Can be found in hardware stores
Cardboard Tube/Roll - Can be found in paper towels and toilet paper
Small Plastic Container - Can be found in certain products
(OPTIONAL) Christmas or Winter themed wrapping paper - Can be found in stores
(OPTIONAL) Sharpie or Marker - Can be found in certain stores
Cardboard Scraps - Can be found almost anywhere
Step 1: Cutting Holes
For step 1 Start by cutting two holes. One on the top and one an inch from the bottom
Result should look like the picture above
Step 2: Making the Tray
for this step you will need thin cardboard. Now cut it like I did in the picture but use wood glue instead of regular.
Step 3: Gluing the Tray
Now on the flaps connecting to themselves glue them together. But on the open flaps slide the flat side underneath and glue. Now glue the open flaps to the cardboard box
Step 4: Cardboard Surgery
Now open up the box. This step is very important so don't sΜΆcΜΆrΜΆeΜΆwΜΆ ΜΆuΜΆpΜΆ I mean mess up. Now cut two holes on opposite sides. Now on your cardboard roll cut a hole where the candy will go/fall into. Now insert it into the holes
Step 5: Cardboard Surgery Part 2
now on the top hole put your plastic container in (dont add the candy yet) now back on the inside put a slope underneath the cardboard roll leading to the hole an inch from the bottom from Step 1. Now cut cardboard circles and with wood glue put it inside the roll but just on the outside
Step 6: DECORATING
Now if you're lazy like me you can stop right now. BUT! If you want to go to the extra mile you can cut a V shape on your box and fill the V with hard plastic to show the small candy or you could wrap the box in wrapping paper! The possibilities are endless! Well thank you for reading and hopefully doing my intructable and with that, have an awesome day :)
