DIY Capacitive Stylus
Intro: DIY Capacitive Stylus
Most smart phones and tablets have capacitive touch screens. This is an impressive bit of technology that lets you interact directly with the screen using only your finger. But there is one problem with this kind of interface, messy finger foods. Nobody wants streaks of food all over their screen. One way to solve this problem is to use capacitive stylus. But you don't need to spend a lot of money on a commercial stylus when you can make one for free out of everyday items. In this instructable, I am going to share with you a few of my favorite designs for a DIY capacitive stylus.
STEP 1: Background Information
There are several different kinds of capacitive sensing. But in general, they all work by using an array of sensors to monitor the electrostatic field around the screen. When your finger touches the screen, it changes the electrical capacitance of that portion of the screen. This is detected as a change in voltage at various locations. The microprocessor captures, filters, and analyzes the data. Then it calculates the coordinates of where the touch occurred. You can read more about capacitive sensing here: http://en.wikipedia.org/wiki/Capacitive_sensing
When a stylus is used, the same principles apply. The only difference is that the stylus is acting as a conductor to transmit electrical charge between your hand and the phone. In order to function properly, a capacitive stylus must meet several criteria.
1. A conductive surface: It must be able conduct an electrical charge between your hand and the screen. If the material is too resistive or if the distance between your hand and the screen is too great, the signal reaching the screen may be too weak to be detected.
2. At least 1/4 inch wide: When filtering data, the processor ignores areas that are significantly smaller than a human finger tip. This helps avoid unintentional activation. Having a stylus that is about 1/4 inch wide will ensure that there is enough surface area to be detected.
3. A relatively flat end: Having a flat tip ensures that the whole face can get close enough to the screen to be detected.
4. A smooth surface: This will ensure that you don't scratch up your screen.
Following these criteria, you can find a wide variety of common items that can be used to activate a capacitive touch screen. Here are five of my favorite designs for a DIY capacitive stylus.
STEP 2: Metal Pen Stylus
The back end of many metal pens may be used as a stylus without any modification. The more metal there is in the pen, the more sensitive and more reliable it will be. When selecting a pen be careful to avoid shiny plastic that may look like metal. This is probably the most convenient stylus because it can function as both a pen and a stylus.
STEP 3: Battery Stylus
The negative end of a battery (such as a AA, AAA, or AAAA) can also act as a stylus without any modification. However, if you would like to make it more sensitive, you can remove any insulating wrapping. A battery makes a great impromptu stylus. With the prevalence of hand help electronics we are rarely far from a battery of some kind.
STEP 4: Sponge Stylus
Probably the most interesting material that can be used to activate a capacitive touch screen is a sponge. It's cheap, effective and actually cleans your screen as you use it. But a sponge is a bit too flexible to make an effective stylus as it is. To fix this, the easiest thing to do is to insert the sponge into a metal pen barrel or other metal tube. This gives it shape and makes it a lot easier to work with.
Cut off a strip of sponge that is about 1/2 inch wide and about 3 inches long. Pinch the end of the sponge and twist it into the barrel until you have 1/2-1 inch sticking out the end. Make sure that the sponge is deep enough that it makes good contact with the metal housing. Then trim the tip of the sponge with a pair of scissors and round it off. This helps make the stylus more accurate.
The only problem with using a sponge as a stylus is that it will not work if it is completely dried out. The water in the sponge helps conduct the charge. So periodically you need to rewet the sponge. It doesn't need to be soaked, just moist enough that the sponge is flexible.
STEP 5: Office Supply Stylus
While most office supplies are either too small (like paper clips) or too large (such as staplers and hole punches) to be conveniently used as a stylus, there are quite a few that work quite well. Some examples of metal office supplies that will work as a stylus are scissors with metal handles, a name tag clip, binder clamps, or an unbroken bunch of staples. The best way to figure out what will work is to just open up your office supply drawer and start trying different things out.
STEP 6: Foil Stylus
Pretty much anything wrapped in foil can work as a stylus. A pencil or pen wrapped in foil is probably the simplest example. Just tear off a piece of foil that is about 3-4 inches long. Then roll it onto the pencil leaving about an inch of foil sticking out past the eraser. When it is rolled up, fold this extra bit of foil over the end. Then fold up any sharp ends. To finish smoothing the end, you may want to press it against a table on all sides to ensure that the end is flat and free of any sharp edges. The creased foil should hold itself in place, but if you use tape to secure the foil, make sure that there is enough exposed foil to make a good contact with your hand. If the stylus is not very responsive, you may wish to adjust the shape of the tip by either pressing it into a different shape or rerolling it.
STEP 7: Other Materials
There are a lot of other materials that can be used to activate a capacitive touch screen. Here are just a few.
The head of a bolt or screw
Nails with a wide head
Silverware
The inside of a zipper
A capacitor
A metal thumbtack
A rolled up green leaf
Wet paper towel/napkin
A stack of quarters
A freshly cut twig or stem
A pocket knife or multi-tool
Large Keys
The back end of a drill bit
Anti-static film
Anything porous that is wet
Anything that is made of metal that has the right shape
This is just a short list of some materials that will work. Feel free to try out whatever you have laying around. If you think of a particularly interesting material that works, leave a comment and share.
Silverware
A capacitor
A metal thumbtack
A stack of quarters
Large Keys
Anti-static film
56 Comments
GuineaPigKitKat 7 years ago
mdawg983 4 months ago
hack_anything∞ 3 years ago
Darksonic232 2 years ago
412654 11 months ago
aahaan.jain 2 years ago
DeniseR60 1 year ago
JaylenW33723566 1 year ago
REDMAXCRAFT builds 3 years ago
Already in use my 1 year ago
orangeade. 8 years ago
dax321 2 years ago
sanlpetty 2 years ago
I am an older lady with fat fingers, trying to type a text or play a game on my phone with my fingers is frustrating. Also just as frustrating is using a worn out stylus. A quick fix is to use saran wrap.
hhhhhhhhhhhhm 2 years ago
Flip Recrute 2 years ago
lacamera 4 years ago
mkam0001@gmail.com
EMIL¥ 3 years ago
Motherboards can be repaired but you’ll have to find a shop willing to do it, it’s a difficult and fragile repair and very expensive.
I bought a lightning to female USB adapter, I was then able to plug in a usb on a standard keyboard.
I also later used a Bluetooth keyboard attached to an iPad mini case, by using the first keyboard to turn on and pair Bluetooth.
This is good to retrieve a back up of what was on that phone soooooo you won’t lose all your information
Nandu2u2 4 years ago
LadyWalker43 5 years ago
