Introduction: DIY: Carbide Line Scriber
Like many of my fellow instruct-a-nauts I up-cycle/re-cycle as much as I can. Many of the parts in this instructable have been repurposed. Primarily I built this scribe to get a center line on the knives I build, but this can be used for many other things. During the design process I had thought a squared slide arm would be best. After scrounging my parts and supplies I found this 3/8" aluminum tube that was threaded and had its own screw. perfect match! and it is much easier to drill a circular hole than a square one.
I hope you find this useful and as always feel free to ask any question and please vote and rate as you see fit, thank you!!
MATERIALS
1 1/2" x 1/4" aluminum bar stock
3/8" aluminum tubing (I got this from a broken DVD rack, one side is already drilled and tapped with its own screw included)
scribe refill
3/8" rubber nipple
assorted screws
TOOLS
hacksaw
belt sander
drill press
center punch
vice
drill bits
tap and die set
polish
sand paper
square
MATERIALS
scribe refill
3/8" rubber nipple
assorted screws
TOOLS
hacksaw
belt sander
drill press
center punch
vice
drill bits
tap and die set
polish
sand paper
square
Step 1: Sizing and Cutting
- Grab your aluminum bar stock ( you could use steel as well) and cut off a 2" to 3" section.
- With a sharpie and square mark your center. Also mark the center at the top of the bar stock.
- Using a center punch make a pilot hole.
Step 2: Drilling Your Holes
- Drill your first 3/8" hole in the bar stock where you marked. a clamp might be needed.
- On the top of the bar stock drill your 7/32" hole for the set screw. make sure it is centered.
- 7/64" drill bit is used for the 3/8" aluminum tube. you want to set the hole about 1/4" from the edge. Depending on the scribe you find this hole might need to be a different size.
Step 3: Tapping the Top
OK! this was the first time i have tapped any thing, I am not an expert on this subject. Infact, I broke a tap and had to shorten the bar stock, live and learn.
- Get cutting lube and the tap.
- Tap it! be sure to back out every half turn or so and do no apply too much pressure!
Step 4: Sand and Polish
- Square your edges using a belt sander
- sand and polish the front of your bar stock.
Step 5: Putting It All Together
- Grab that bar stock and insert the aluminum tube through the hole.
- Add the set screw.
- Insert the carbide tip and set screw.
- Put the rubber nipple in the back of the tubing.
If you have and questions or comments please leave them at the bottom.
Thanks for looking.
Step 6: UPDATE
I added some measurements to the side of the arm of the scribe, It ain't pretty but it works!
