Introduction: DIY Cardboard Glue Gun Stand
In this tutorial, You will learn how to easily and quickly make a cardboard glue gun stand for your workshop.
This DIY Cardboard glue gun stand is very practical and will make your work a lot easier by keeping the gun and glue sticks near by you, and making sure no glue will drip on your work table!
Don't Feel Like Making one? Buy one Here :) https://amzn.to/2WY1zBk
I hope you find this DIY Cardboard glue gun stand tutorial easy and helpful and as Always: Enjoy & Subscribe!
Tools and Materials I use
OLFA 24" x 36" Double-Sided Self-Healing Rotary Mat
Surebonder PRO8000A Glue Gun, 180-watt
Stainless steel Cork Back Ruler 24' by Studio 71
Bosch 12-Volt Max Brushless 3/8-Inch Drill/Driver Kit
Bosch 91-Piece Drilling and Driving Mixed Set MS4091
TEKTON 65731 Scratch and Punch Awl
Casio MS-80B Standard Function Desktop Calculator
Fiskars 01-004761J Softgrip Scissors Straight Stainless Steel
Dyson Cyclone V10 Animal Lightweight Cordless Stick Vacuum Cleaner
Elmer's E461 Craftbond Tacky Glue
Dremel Gg01 Multipurpose High Temp Glue Sticks
My Video shooting Hardware
Velbon VideoMate 538/F Camera Tripod
KobraTech Cell Phone Tripod Mount
Follow Me On Social Media
Software I use
OS : Linux Mint
Video Editor : OpenShot
Step 1: Prep the Parts
A photo says more than a 1000 Words ;).
All measurements are in cm, but can easily be converted to inches using this Google Converter.
Feel Free To use this template anyway you want, personal, commercial etc..
However, I hold the Intellectual property of the photos and video in this Article :).
Step 2: Glue the Rear Walls
Start by gluing the rear wall, add a second layer if the base of your gun is wide or high.
This template is made for the Dremel 940 but it should work with any other gun :)
if your gun is shorter than this one, try gluing the rear wall closer to the center.
Step 3: Glue the Side Walls
These side walls will make sure the cardboard base will not warp over time. Add a second layer if needed.
Step 4: Assemble the Glue Stick Box
The glue stick box parts have the following measurements:
front : 8 x 8 cm
Rear : 8 x 12 cm
Sides : 8cm front side x 8cm bottom x 12cm rear side x Top (connect the last side together).
Step 5: Glue the Front Stop
Place your gun on the stand, and eyeball where the nose will sit, then add the front stop to make sure it sits perfectly and will drip inside the stand every time.
Step 6: Done
Add a small Cardboard drip piece, that will collect the glue drips after each work session and you are done.
Congratulations, You just made yourself a practical and cool Glue Gun Stand from Cardboard, that will keep your gun and sticks close to you while working, and make sure no glue will drip on your work table.
I hope you found this tutorial useful, check out my YT channel for more cool projects. Thanks!
