Introduction: DIY Cardboard Tank
The history of the tank begins with World War I. Armored all-terrain fighting vehicles were introduced to combat the trench warfare, ushering in a new era of mechanized warfare. By World War II, tank design advanced significantly.
Though initially raw and unreliable, tanks eventually became a mainstay of the ground armies. In this quick tutorial, I am going to make a DIY Tank using cardboard sheets. It will only take 20 minutes of your valuable time to create this DIY Masterpiece.
Step 1: Components Used
To create the DIY Tank we need:
  • Cardboard Sheet
  • A4 Paper
  • Permanent Marker
  • Scissor and a Knife
  • Hot Glue Gun
  • Optional Plaster of Paris
  • Optional Sandpaper
  • Water Color and Coloring Brushes
Step 2: The Template
So, this is the template I created for the Tank's body. I will provide the link in the description below. Using a paper cutting scissor, I extracted all the shapes from the template.
Step 3: Cutting the Cardboard
Then I traced the paper-cutouts on pieces of cardboard and using both scissor and knife I extracted all the pieces of cardboard that I need for this project.
Step 4: Joining Pieces
Using a hot-glue gun I joined all the cardboard cutouts.
Be very careful while using a hot-glue gun. Use gloves as much as possible to avoid the hot glue from burning your hand and fingers. By using wood-glue instead of hot-glue you can get a cleaner and stronger finish, but hot glue is faster. Hot glue can also be more forgiving as you can re-heat and re-glue if you're unsatisfied with your seam. Try applying the glue from the inner side as much as possible to leave the outer side neat and clean.
Step 5: Coloring
So, this is how my cardboard Tank looks like. Using green, brown and black Acrylic Color I painted the body of the Tank. It totally depends on what color you want to apply; but, please do not paint it red or pink, ha ha....
Step 6:
By changing the shape and size of the canon, body, caterpillars or the top section of the tank, or by applying a different set of colors you can generate a new model and add to your DIY collection.
Step 7: Thanks
Thanks again for checking my post. I hope it helps you.
If you want to support me subscribe to my YouTube Channel: https://www.youtube.com/user/tarantula3
Full Blog Post: https://diy-projects4u.blogspot.com/2021/06/diy-c...
Video: https://diy-projects4u.blogspot.com/2021/06/diy-c...
Cardboard Template:
1. Tank : https://drive.google.com/file/d/1rk7nt5us-fkiT5n4...
Support My Work
BTC: 35ciN1Z49Y1bReX2U7Etd9hGPWzzzk8TzF
DOGE: DDe7Fws24zf7acZevoT8uERnmisiHwR5st
LTC: MQFkVkWimYngMwp5SMuSbMP4ADStjysstm
ETH: 0x939aa4e13ecb4b46663c8017986abc0d204cde60
BAT: 0x939aa4e13ecb4b46663c8017986abc0d204cde60
Thanks, ca again in my next tutorial.
