Introduction: DIY Cedar Planter Box
Want to build an easy planter box? Check out this plan. All you need to build this is a saw (miter saw, circular saw, hand saw) and a drill! Easy breezy, and you'll have a beautiful cedar planter box in only a few hours.
Step 1: Purchase Materials & Break Down Pieces
| Quantity | Item | Price |
| 4 | 1-in x 4-in x 8-ft, Cedar | $7.98 |
| 2 | 1-in x 2-in x 8-ft, Cedar | $3.95 |
| 16 | 2" Exterior Screws | $5.98 |
| ~50 | 1 ¼" Exterior Screws | $9.37 |
| Total | $55.17 |
Note: you will have screws left over, so this is actually slightly cheaper than $50. You could probably build two of these boxes for $90.
DIY Planter Box Cut List| Description | Quantity | Length | Width | Thickness |
| Bottom Slats | 8 | 12" | 3 1/2" | 1" |
| Short Side Rails | 4 | 13 1/2" | 1 1/2" | 1" |
| Side Rails | 4 | 28" | 1 1/2" | 1" |
| Side Slats | 22 | 11" | 3 1/2" | 1" |
Cut these on the miter saw with a stop block to speed up the process.
Step 2: Assemble Sides of Planter Box
This planter box consists of four separate panels and the bottom slats. To build your panels, follow the steps below.
To assemble the short side panels, attach three slats and two rails to each other using 1 ¼" screws from the inside. Make sure to pre-drill your holes, as this thin cedar is very prone to splitting. The slats are flush with the top of the rail, set in 1 ½" from the sides of the rails, and ¾" from the bottom rail.
To assemble the long side panels, make sure the slats are flush on the top, left, and right. Set in the bottom of the rails ¾". Again, use 1 ¼" screws.
Step 3: Assemble Planter Box Frame
Once your two long sides and two short sides are done, attach them at the corners using 2" exterior screws. I used two screws per corner, for a total of 8 screws at each end.
Step 4: Attach Bottom of Planter Box
To attach the bottom, place the slats in the recess created by insetting the slats and attach them with 1 ¼" screws. Once they are attached, drill a few holes for drainage using a large drill bit or Forstner bit.
Step 5: Enjoy Your DIY Planter Box!
Fill with some good quality soil and plant your fruits, vegetables, or whatever you happen to be growing. Hope you enjoyed this build! To make sure you don't miss any future Crafted Workshop videos, subscribe to our YouTube channel! If you really enjoyed this video, consider supporting us on Patreon! And last, follow us on social media on Facebook, Twitter, Instagram, Pinterest and Snapchat at @craftedmagazine! Thanks for your support.
