Introduction: DIY || Clap Controlled Room Light
Ever wondered to control your Home Appliances with a CLAP? Then you are at right place!
Here, I am going to show you how you can control any Home Appliance be it - Room Lights, Fan, Television or Audio System with just a Clap.
This project is based on the Clap ON - Clap OFF circuit which turns the load (here, Home Appliance) ON on first clap and turns it OFF on second clap.
Step 1: Materials Required
To make this project, we require:
- IC 4017
- Relay (6V)
- Condenser Microphone
- Transistors – BC 547 (3)
- Resistors – 330 Ω, 1 K Ω(2), 100 K Ω
- Diode – 1N4007
- Switch
- LED
- Battery (9V) and Battery Clip
- Wires
- PCB
- Cardboard
- Paper
Major Tools required:
- Soldering Iron and Solder Wire
- Hot Glue Gun
Step 2: Circuit Diagram
This circuit is basically Clap ON - Clap OFF circuit which can be built using either IC 4017 or 555 Timer IC.
Here, I am making with IC 4017. If you want to make using 555 Timer IC then follow the circuit discussed here.
