Introduction: DIY Class D Audio Amplifier
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you why a class AB amplifier is pretty inefficient and how a class D amplifier on the other hand improves this efficiency. At the end I will show you how we can apply the theory of operation of a class D amp to a couple of common components in order to create our own DIY class D audio amp. Let's get started!
Step 1: Watch the Video!
The video gives you all the information you need to build your own class D audio amp. During the next steps however I will present you some additional information to make the project even simpler.
Step 2: Order Your Components!
Here you can find a parts list with example sellers (affiliate links):
Ebay:
1x 3.5mm Audio Jack: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LM393 Comparator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TLC555 Timer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 74HC04 Inverter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x IR2113 MOSFET Driver: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x IRLZ44N MOSFET: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 7805 Voltage Regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 7812 Voltage Regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x PCB Terminal: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x 47µF, 1x 22µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
7x 220nF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x UF4007 Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 10kΩ, 2x 10Ω, 1x 2kΩ Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 33µH Inductor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Aliexpress:
1x 3.5mm Audio Jack: https://s.click.aliexpress.com/e/_dYyosJz
1x 10kΩ Potentiometer: https://s.click.aliexpress.com/e/_dX83GAF
1x LM393 Comparator: https://s.click.aliexpress.com/e/_d7ObgpD
1x TLC555 Timer: https://s.click.aliexpress.com/e/_dTrUY9D
1x 74HC04 Inverter: https://s.click.aliexpress.com/e/_d8c7LDl
1x IR2113 MOSFET Driver: https://s.click.aliexpress.com/e/_d7SJq6b
2x IRLZ44N MOSFET: https://s.click.aliexpress.com/e/_dWhSrDl
1x 7805 Voltage Regulator: https://s.click.aliexpress.com/e/_dXSrfiP
1x 7812 Voltage Regulator: https://s.click.aliexpress.com/e/_d8OcXHl
2x PCB Terminal: https://s.click.aliexpress.com/e/_dYbstfZ
3x 47µF, 1x 22µF Capacitor: https://s.click.aliexpress.com/e/_d7dOwRz
7x 220nF Capacitor: https://s.click.aliexpress.com/e/_dU4FEsB
3x UF4007 Diode: https://s.click.aliexpress.com/e/_dYR45Bh
2x 10kΩ, 2x 10Ω, 1x 2kΩ Resistor: https://s.click.aliexpress.com/e/_dTPpXjt
2x 33µH Inductor: https://s.click.aliexpress.com/e/_d6A4mKL
Amazon.de:
1x 3.5mm Audio Jack: http://amzn.to/2rpKbHN
1x 10kΩ Potentiometer: http://amzn.to/2rT8PSN
1x LM393 Comparator: http://amzn.to/2rG3dKL
1x TLC555 Timer: http://amzn.to/2qUBsd9
1x 74HC04 Inverter: http://amzn.to/2rGfizn
1x IR2113 MOSFET Driver: http://amzn.to/2rpQWtr
2x IRLZ44N MOSFET: http://amzn.to/2rT1X7R
1x 7805 Voltage Regulator: http://amzn.to/2ryYCI3
1x 7812 Voltage Regulator: http://amzn.to/2qUK5EG
2x PCB Terminal: http://amzn.to/2qQ1ymz
3x 47µF, 1x 22µF Capacitor: http://amzn.to/2qPYdE6
7x 220nF Capacitor: http://amzn.to/2rGg1k5
3x UF4007 Diode: http://amzn.to/2qUxLnM
2x 10kΩ, 2x 10Ω, 1x 2kΩ Resistor: http://amzn.to/2ryTxiV
2x 33µH Inductor: http://amzn.to/2rG8wtn
Step 3: Build the Circuit!
Here you can find the schematic of the project with and without the LM386 preamplifier. Feel free to use the pictures of my finished perfboard circuit as a reference.
You can also find the schematic on EasyEDA: https://easyeda.com/editor#id=74409197e62e4ff6b09d...
Step 4: Success!
You did it! You just built your own Class D Audio Amplifier!
Feel free to check out my YouTube channel for more awesome projects:
https://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
