Introduction: DIY - Coin Bank Box Easy and Unique
I will show you how to make coin saving box easy, unique and cheapest
Step 1: Dimension Cutting Cardboard for Coin Insert Slot
Cut the cardboard as like in the image for coin insert slot the top side of box.
Step 2: Mount the Part Coin Insert Slot With Glue
glue the coin insertion slot with the cardboard that was cut in step 1
Step 3: Mount Body of Box
Mount the parts boy of box with glue
Step 4: Install the Coin Holder Before Entering the Box
first cut 4 pieces of cardboard with a length of 7 cm and a height of 5 cm.
then glue the cardboard so that it becomes two pieces, the first glue it to the box wall and the second is attached in the middle using a bamboo stick to hold the coins before entering the box.
then put the cardboard loop holder in the middle and put a rubber band.
Step 5: Mount Top Side of Box
Mount top side of box using glue.
Step 6: Coin Insertion Test
test for coin insertion to work properly.
Step 7: Mount All Body of Box
mount all body of box using the glue.
Step 8: Mount Wheel at Bamboo Stick.
mount wheel at bamboo stick using the glue.
Step 9: Finish
The final result of the coin saving box.
Thank you.
