DIY Corner Radius Templates
Intro: DIY Corner Radius Templates
A set of corner radius router templates is one the most useful accessories for the router table. This 'ible presents an easy way to make your own!
Stuff you need:
STEP 1: How It Works
To ensure perfect templates: a bearing guides the radius cut, then a jointing-action flattens the adjacent side. I drilled a hole for a view of the cutting action.
STEP 2: Plans
Free plans for the jig are attached!
STEP 3: Hijack a Bearing
The bearing of a flush trim router bit is removed. This will be used (temporarily) to make the templates!
STEP 4: Pick Your Radius
Pick the radius you want, and place the bearing accordingly.
STEP 5: Set Up the Jig (1 of 2)
The corner of the jig should be in contact with the bearing.
STEP 6: Set Up the Jig (2 of 2)
The edge of the jig should be parallel to the workpiece.
STEP 7: Routing Action!
Pivot the workpiece around to make the radius cut.
STEP 8: Trim It
Cut the template at the mitre saw to any desired size.
STEP 9: Drill It
Make a hole so you can hold onto the template while in use.
STEP 10: Cut Aluminum Angle
Two aluminum bits form the edges. A length of aluminum angle is cut at the mitre saw. Aluminum machines quite well with regular woodworking tools.
STEP 11: Drill the Aluminum
Create two screw holes in each aluminum piece.
STEP 12: Complete the Template
Screw down the aluminum angles.
STEP 13: Make Any Radius!
The jig can make any radius template you can imagine.
STEP 14: Happy Routing!
HIGH FIVE for reading!
6 Comments
Jobar007 7 years ago
Really neat idea. I like the use of the tool that you are making the jigs for.
danprice48 7 years ago
Jayefuu 7 years ago
Thanks for posting more here Kriss! This one's definitely on my "to make" list
HomeBrewski 7 years ago
I really enjoy your instructables, than you for posting this. Hope you make more (I have subscribed to you on YouTube also).
That straight edge you used to measure 3/4" from the edge... do you happen to have a link to that? Very cool!
Toolify 7 years ago
Here's a link to the ruler: http://amzn.to/20TBZIx
mortenlc 7 years ago
Very nice. Thanks!
Cool idea with the "peephole" :-)
