Introduction: DIY Cross Ion Refill Variation B
About: The thing I like about making Instructables is that it forces me to slow down and consider each step without taking anything for granted. If I am systematically trying to explain it to people on the Web, it ma…
The Cross Ion is the finest writing implement I've ever owned. The Cross gel ink refills, however, not so much. They are considerably overpriced and to add insult to injury, they tend to stop writing after a few weeks.
This Instructable is a variation on the one submitted by computercolin. His was a great idea that I implemented slightly differently and I wanted to share.
Step 1: Gather Materials
The materials I used in this project included:
knife
Staples gel ink mini pens
an empty (or as empty as possible) Cross refill
not pictured:
tack (for punching a small hole)
a sink
rubbing alcohol
paper towels
Step 2: Disassemble Mini Refill
Disassemble the gel ink mini pen. There are two items we are interested in: the pen insert and the end cap.
The rest of the pen, I'm setting aside to make an iPod Touch stylus.
Step 3: Prepare Mini Refill
The mini refill is slightly too long for our needs. I lopped the end off of it with the knife.
Step 4: End Cap
There needs to be a vent hole for the ink to flow. I punched mine in the end cap.
Step 5: Prepare the Widener
We are going to use an empty ink refill to act as a widener, otherwise the spring won't retract the pen when you close it.
THIS STEP WILL BE MESSY!
However, you are only going to ever need to do this once.
It is important to find an almost empty refill for this because we are going to dump the ink out of it. You don't want to have to deal with more ink than necessary.
It CAN be done with minimal mess. I was wearing dress clothes when I did it and didn't get a drop on me (although the janitorial staff may wonder why they can't get the stain out of the sink in the men's bathroom).
1. Pop the end cap off.
2. Cut around the ridge where it narrows down, thus cutting the ballpoint tip off of the plastic well.
3. Once you've cut all the way through, put it on a paper towel and let gravity and capillary action take the ink out as much as possible. Be patient. You can try to rush it by running water into the back end, but do it slowly. You don't want to splash. DO NOT turn the pen upside-down and pour water into the narrow end (this caused considerable splashing of ink). Note even the clear gel stains.
4. When you've almost got all of it, roll up a snake of paper towel and push it through the inside to clean the last of the ink out.
5. Use rubbing alcohol to clean up messes and to get the last of the ink out. (optional)
Step 6: Widen the Opening
Depending on how your cut went, this may be an optional step. When I did it, the hole didn't quite accept the mini pen insert. I just bored out the hole with the knife slightly. It didn't take much.
Step 7: Insert Pen
Time to put it all together.
Slide the refill into the widener. It should be snug.
Pop the ventilated cap on the other end. You may need to grab it by the ballpoint end and wiggle it around to center it. (Here is where the Cross caps from their refills come in. I put them on so I can grab the ballpoint end without writing all over myself. Not that it matters since I'm covered in ink having just cut open a refill, but the next time, it will be much neater).
Step 8: Success!
The shape of the refill is now exactly the same as a branded Cross refill. You can reuse the widener and the end cap the next time the ink runs out. Just cut off the end of another Staples insert.
You cannot see through the Ion window how much ink is left, but that isn't such a big deal to me since that was never an accurate indicator of how much longer my pen was going to last anyway.
Thanks again to computercolin for pointing the way and showing me how to continue to use my favorite pen while not wasting money on bad ink.
