Introduction: DIY DC Electronic Programmable Load
This is my project on making a programable DC electronic load which I can use to test power supplies, battery capacity, etc. Obviously there are many such instruments available in the market but those are pretty expensive for a hobbyist like me. So I decided to make my own DC electronic load which can fulfil my requirements with a good amount of precision.
Step 1: Electronic Load
This method is the most practical method of electronic load. Instead of a resistor we will use a MOSFET to dissipate the power. Now a MOSFET is a semiconductor switch which turns on when sufficient voltage is applied to the gate terminal. Take a look into the RDS value and VGS from the table.
If you observe the table carefully, you will notice that it has a minimum resistance (RDS) when 10V or more is applied to the gate. But the MOSFET starts conduction at the gate threshold voltage (2 – 4 V). Now take a look into the characteristics curve of the same MOSFET.
From the characteristics curve we can clearly observe that the MOSFET offers more resistance when we apply voltage between 4V to 10V. To use a MOSFET as load, we are going to use this property of MOSFET.
Now in order to apply a variable voltage at the gate of MOSFET we need to convert digital PWM signal to analog voltage. We can do this easily with an RC filter or LC filter. But that’s actually a very crude method and to my experiment it didn’t gave me a satisfactory result.
If you want to have a look into my experiment on breadboard, you can definitely watch this video:
Step 2: Schematic of Final Design V1.0
Step 3: Arduino Code
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <Adafruit_ADS1X15.h>
#include <Adafruit_MCP4725.h>
Adafruit_MCP4725 dac;
Adafruit_ADS1115 ads;
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define clk 2
#define dt 3
#define sw 4
char screen = 0;
char arrowpos = 0;
float power = 0;
float current = 0;
float curcurrent = 0;
float curpower = 0;
float curvoltage = 0;
int counter = 0;
uint32_t dac_value;
volatile boolean currentmode = false;
volatile boolean powermode = false;
volatile boolean TurnDetected = false;
volatile boolean up = false;
volatile boolean button = false;
byte customChar1[8] = {
0b10000,
0b11000,
0b11100,
0b11110,
0b11110,
0b11100,
0b11000,
0b10000
byte customChar2[8] = {
0b00100,
0b01110,
0b11111,
0b00000,
0b00000,
0b11111,
0b01110,
0b00100,
ISR(PCINT2_vect) {
if (digitalRead(sw) == LOW) {
button = true;
void isr0 () {
TurnDetected = true;
up = (digitalRead(clk) == digitalRead(dt));
void setup() {
lcd.init();
lcd.backlight();
ads.begin();
dac.begin(0x60);
dac_value = 0;
dac.setVoltage(dac_value, false);
pinMode(sw, INPUT_PULLUP);
pinMode(clk, INPUT);
pinMode(dt, INPUT);
PCICR |= 0b00000100;
PCMSK2 |= 0b00010000; // turn o PCINT20(D4)
attachInterrupt(0, isr0, RISING);
ICR1 = 2047;
lcd.createChar(0, customChar1);
lcd.createChar(1, customChar2);
lcd.clear();
lcd.print("digitaleclab.com");
delay(3000);
screen0();
lcd.setCursor(0, 0);
lcd.write((uint8_t)0);
void loop() {
if (currentmode) {
curcurrent = ads.readADC_Differential_0_1() * 0.1875 / 1000.00 / 0.0975;
if (counter == 100) {
lcd.setCursor(4, 1);
lcd.print(curcurrent);
lcd.print("A ");
counter = 0;
if (curcurrent < current) {
if (dac_value < 4095) {
dac_value++;
else {
else {
if (dac_value > 0) {
dac_value = dac_value - 1;
else {
counter++;
delayMicroseconds(100);
if (powermode) {
curvoltage = ads.readADC_SingleEnded(2) * 0.1875 * 11.13 / 1000.00;
curpower = curvoltage * curcurrent;
//Serial.println(curpower);
lcd.print(curpower);
lcd.print("W ");
counter = 0;
if (curpower < power) {
dac_value++;
else {
else {
else {
counter++;
if (TurnDetected) {
delay(200);
switch (screen) {
case 0:
switch (arrowpos) {
case 0:
if (!up) {
screen0();
lcd.setCursor(0, 1);
arrowpos = 1;
break;
case 1:
if (up) {
screen0();
arrowpos = 0;
break;
break;
case 1:
switch (arrowpos) {
case 0:
if (!up) {
screen1();
arrowpos = 1;
break;
case 1:
if (up) {
screen1();
arrowpos = 0;
else {
screen1();
lcd.setCursor(7, 1);
arrowpos = 2;
break;
case 2:
if (up) {
screen1();
arrowpos = 1;
break;
break;
case 2:
if (up) {
power = power + 0.1;
lcd.setCursor(7, 0);
lcd.print(power);
lcd.print("W");
lcd.write((uint8_t)1);
lcd.print(" ");
else {
power = power - 0.1;
if (power < 0) {
power = 0;
lcd.print(power);
lcd.print("W");
lcd.print(" ");
break;
case 4:
switch (arrowpos) {
case 0:
if (!up) {
screen4();
arrowpos = 1;
break;
case 1:
if (up) {
screen4();
arrowpos = 0;
else {
screen4();
arrowpos = 2;
break;
case 2:
if (up) {
screen4();
arrowpos = 1;
break;
break;
case 5:
if (up) {
current = current + 0.1;
lcd.setCursor(9, 0);
lcd.print(current);
lcd.print("A");
lcd.print(" ");
else {
current = current - 0.1;
if (current < 0) {
current = 0;
lcd.print(current);
lcd.print("A");
lcd.print(" ");
break;
if (button) {
delay(200);
switch (screen) {
case 0:
if (arrowpos == 0) {
screen = 1;
screen1();
else {
screen = 4;
screen4();
break;
case 1:
switch (arrowpos) {
case 0:
screen = 2;
screen2();
break;
case 1:
powermode = true;
screen = 3;
screen3();
break;
case 2:
screen = 0;
screen0();
break;
break;
case 2:
screen = 1;
screen1();
break;
case 3:
powermode = false;
dac.setVoltage(0, false);
dac_value = 0;
counter = 0;
screen = 1;
screen1();
break;
case 4:
switch (arrowpos) {
case 0:
screen = 5;
screen5();
break;
case 1:
screen = 6;
screen6();
currentmode = true;
counter = 0;
break;
case 2:
screen = 0;
screen0();
break;
break;
case 5:
screen = 4;
screen4();
break;
case 6:
screen = 4;
screen4();
dac_value = 0;
break;
arrowpos = 0;
button = false;
void screen0() {
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("Const. Power");
lcd.setCursor(1, 1);
lcd.print("Const. Current");
void screen1() {
lcd.clear();
lcd.print("Power:");
lcd.print(power);
lcd.print("W");
lcd.print("Start");
lcd.setCursor(8, 1);
lcd.print("Back");
void screen2() {
lcd.clear();
lcd.print(power);
lcd.print("W");
void screen3() {
lcd.clear();
lcd.print("Set:");
lcd.print(power);
lcd.print("W");
lcd.print("Cur:");
lcd.print("W");
lcd.setCursor(11, 1);
lcd.print("STOP");
void screen4() {
lcd.clear();
lcd.print("Current:");
lcd.print(current);
lcd.print("A");
lcd.print("Start");
lcd.print("Back");
void screen5() {
lcd.clear();
lcd.print(current);
lcd.print("A");
void screen6() {
lcd.clear();
lcd.print("Set:");
lcd.print(current);
lcd.print("A");
lcd.print("Cur:");
lcd.print("A");
lcd.print("STOP");
}Step 4: Part 2 of Final Built Video
Step 5: Social Links
If you like my work and want to keep in touch for more blogs and tutorials, please subscribe to my YouTube channel: https://www.youtube.com/channel/UCNCysNXP8MPSaOOKa...
You can also visit my website: https://digitaleclab.com/
Follow my page on Instagram: https://www.instagram.com/digitaleclab/
Facebook: https://www.facebook.com/digitaleclab
