Introduction: DIY Desktop Laser Cutter Made in Japan
“Laser cutters are expensive!”
People couldn’t afford to have laser cutter for the individual in the past. We really wanted to develop an affordable, useful and capable laser cutter which people could easily afford.
My friend Hirotaka and I worked hard to develop an affordable easy to use laser cutter for about one year. Then finally, our ideas and effort were fully realized.
- Desktop Laser Cutter "Smart Laser Mini"
The Smart Laser Mini is Easy to assemble type of laser cutter and engraver. It is completely do it yourself for example you can make engraving marks on many kinds of surfaces and you can even use this laser to cut on many kinds of materials. This laser cutter is compact in size therefore perfect for household use.
- Open source
People can be freely modify our software and hardware to expand the processing area and add such as adding additional functions.
- 1.6 watts diode laser
It adopted 1.6 watts diode laser for the laser parts. The output is strong enough that it can cut 0.079inch (2mm) of material.
- V-slot for mechanical parts
We adopted open builds V-slot for our mechanical parts, therefore it is simple and easy to assemble.
- Computer software
Computer software works on the Browser. It’s producing by HTML, JavaScript, Python and this is Cross-platform. You can use with Windows、Max OSX、Lunux、Raspberry Pi.
- Arduino Mega.
The control board used Arduino Mega
Arduino Mega’s program is based on GRBL
- Work examples
These are part of our work examples
Engraved on Pancake
http://www.smartdiys.com/blog/wp-content/uploads/2...
Raster processing with “Spider” image data file on black polyester film sheet
http://www.smartdiys.com/en/blog/wp-content/upload...
Engraved on polypropylene sheet
Check it out other our work examples on our blog
Step 1: Manuals
Please refer to the manuals
- Smart Laser Mini
- X-axis assembly
- X-axis motor idler unit assembly
- X-axis driving part’s installation
- Y-axis mini v wheel unit assembly
- Y-axis mini v wheel unit mounting
- Y-axis frame assembly and mounting
- Y-axis motor idler unit assembly
- Y-axis mini v wheel unit adjustment
- Y-axis driving parts mounting
- Limit mounting
- PCB mounting
- Laser module mounting
- Wiring
- Installation of software
- How to use software
- Adjustment and How to use
- Reference: V-slot adjustment
- Open source
