Introduction: DIY Digital Alarm Clock Using REKA:BIT With Micro:bit
LCDs are very popular and useful when you need to display some information like sensors data from your project, and once it comes to use it with REKA:BIT it couldn't be easier. ✨
Join me in this fun tutorial to learn how to make a digital alarm clock using an LCD with REKA:BIT ⏰
- 1x REKA:BIT board with micro:bit v2
- 1x 3V3 I2C 1602 Serial Character LCD
- 2x Potential Meter 10K
- 3x Grove to female cable
- 1x Battery Holder
- 4x Cable ties
- 1x Box
Step 1: Make Alarm Box
- Grab the box and make holes in it as shown in the figures above
Step 2: Attach Components to the Box
By following the figures above:
- Fix REKA:BIT and LCD in the box using cable ties
- The potentiometer should be inserted above the LCD
Step 3: Connection
By following the diagram above:
- Connect both of the potentiometers to the 1st and 3rd ports.
- Connect the LCD to the 6th port
Step 4: Code
Now, connect your REKA:BIT to your device and open MakeCode editor to start programming.
- Add REKA:BIT extension and follow the code block in the picture above
- After completing the code, download it on microbit
You can also view and edit the code by clicking here!
Step 5: Well Done!
Turn on REKA:BIT and start by adjusting the current time, after that proceed to set the alarm
- Hold A button and rotate the potentiometer to adjust the time
- Hold B button and rotate the potentiometer to set the alarm
Great job, have a good day maker :)
