DIY Disc Golf Sack
Intro: DIY Disc Golf Sack
Not too long ago, my son-in-law came up to me, and told me he had an idea for an Instructable. He and many of his friends play disc golf. It is s sport that is growing in popularity. Discs (Frisbees) are thrown from a starting point to the first basket and then from that disc golf basket to the next basket. My son-in-law wanted a “Nut Sack” a bag made to hold discs as he/she plays the game. Money is an issue at our house and the “Nut Sack” (http://www.discgolfmadness.com/nut-sac-disc-golf-bag.html) were more that he was willing to pay. He went shopping and came home with a yard of dark blue canvas, some grey fleece. He brought me his old guitar strap. I have spent this last month contemplating how to create this wonder piece of sporting equipment. Today, I “got ‘er done”. It took longer to make the pattern than it did to make the sack, and this is how I did it.
STEP 1:
Supplies:
½ yard (46cm) canvas
½ yard (46cm) thin fleece
Thread (to match the canvas)
Hand sewing needle
Sewing machine
Fabric scissors
2 buttons
Guitar strap
1 set magnetic clasps
Straight pins
Paper
Ruler
Tape
Pencil
Marker
A set of 6 discs (for measurement purposes)
Hand sewing needle
Sewing machine
Fabric scissors
2 buttons
Guitar strap
Straight pins
Paper
Ruler
Tape
Pencil
Marker
STEP 2:
I taped some sheets of paper together, placed the largest disc from his collection on top of one end of the paper (leaving room for seam allowance). I traced the disc. I then used to ruler to extend the edges of the circle for ¾ inch seam allowance.
STEP 3:
I then measured the stack of 6 discs at 3½ inch (9cm) deep.
STEP 4:
I cut the top ¼ of the circle off and drew a straight line up the side, 9 inches long. I used the disc to create a rounded top. This is the back and flap of the sack. I traced the bottom part and add ½ inch length to the end where the straight edged top will be. This is the front of the sack. I measured the distance around the bottom of the bottom pattern piece and determined that the bottom of the sack needed to be 4½ inches (11-12cm) wide and 22 inches (56cm) long. That pattern part was just a long triangle. All three pieces created.
STEP 5:
Next I laid the pattern pieces on the canvas, cutting out each piece,
STEP 6:
the back/flap, .
STEP 7:
the front
STEP 8:
and the bottom.
STEP 9:
Repeat with the fleece.
STEP 10:
Using straight pins find the center of the bottom piece and the front piece. Ease the bottom piece around the front piece, using as many straight pins as possible. Great!
STEP 11:
Sew the two pieces together making a 5/8 inch seam.
STEP 12:
Repeat adding the other side of the bottom to the back/ flap piece. Again use a 5/8 inch seam.
STEP 13:
After I removed all the pins, I tried all six discs in the sack. Nice fit, yeah this will work.
STEP 14:
Next I cut ½ the seam off,
STEP 15:
and then zigzag the edges closed.
STEP 16:
Repeat the process in steps 10-15 with the canvas, only this time make a 3/8 inch seam. This half of the sack needs to be a bit bigger so that the fleece half will fit nicely into the canvas part.
STEP 17:
Now put the two halves together, with the right sides of each piece facing each other. You may use straight pins to attach the raw edges together. Now is a good pint to figure out where you want the magnetic clasps to go. Put the discs back in the bag
STEP 18:
and use a straight pin mark where on the outside of the canvas you want them to go.
STEP 19:
Sew all the way around the unfinished edges, with a ¼ inch seam allowance, leaving a 3-4 inch gap open. This gap will allow you to turn the sack right side out.
STEP 20:
So turn the sack right side out. Great! Don’t close the gap yet.
STEP 21:
Take the back off of each half of the magnetic clasp. Use a marker to mark where you need to cut little tiny slits for the legs of the clasp to go through.
STEP 22:
Cut the slit and reaching through the opening in the side slip the legs through the slits place the back over the legs and bend them flat.
STEP 23:
This will make sure the part of the clasp will stay in place. Repeat with the other half of the clasp and the flap piece. The backs of each part of the clasp are now inside of the sack, where they can’t be seen. Oh, that looks good.
STEP 24:
Now you can close up the gap, use straight pins to fold in the seam allowance of the gap and sew all the way around the edge of the sack opening.
STEP 25:
Almost done, for my son-in-law wants to use an old guitar strap as the handle of the sack, and I need to add a button to the inside of each side of the sack. Since the button is on the inside, it can be any color you want. I use the tread and needle to sew in each button, leaving a little shank,
STEP 26:
so that there is room for the leather button holes to lay flat. Done!
STEP 27:
My son-in-law loves his new disc golf sack. He tells me he will be showing it off at work tomorrow. Enjoy!
STEP 28:
Update: The day after my son-in-law took his disc golf bag to work (they played a round during lunch) he brought me his bag and asked for 2 changes. First: I removed the buttons on the inside of the bag and just sewed the leather triangle of the strap to the bag its self. This distributed the weight of the bag more evenly onto the strap.
STEP 29:
Second: I put the top part of the magnetic clasp all the way through both layers of fabric. It was not holding well by the fleece alone.
STEP 30:
I then took the top of a button that can be covered by fabric (it was laying all by its lonesome in my button tin) and used E-6000 glue to glue it over the legs of the magnetic clasp.
STEP 31:
This time it is really done! My son-in-law takes it out to disc golf at least once a week and not more adjustments have been needed! ENJOY!
4 Comments
--Cody-- 8 years ago
Very cheap used discs at www.discfinity.com
silentskorn 10 years ago
easilydistracted 10 years ago
jaycruz 10 years ago
