Introduction: DIY Down Firing Port Active Subwoofer
Hey! everyone My name is Steve
Today I’m Gonna show how I Build this 12” Active Subwoofer with Down Firing Port using a 280 Watt Class D plate amplifier
I’ve tuned the Enclosure to 35Hz, The bass I get is very strong and there is no port noise The Amplifier is Great No heating issue
Let's Start
Step 1: Features
Input Power
- 110 - 220V AC
Output Power
- 280Watt RMS @ 4Ohms
Impedance
- 4 Ohms
Frequency Response
- 20Hz - 200Hz
Built-in Protection
- Over Load Protection
- Short Circuit Protection
- Over Heat Protection
Step 2: Thing I've Used
- Pioneer TS-W306R Subwoofer - https://amzn.to/3aF0ZiF
- Class D Audio Amplifier - http://bit.ly/38CVXRV
Banggood
- Circle Cutting Jig -
- Corner Clamp -
- Electric Nail Gun - https://ban.ggood.vip/SmvB
- Wood Trimmer - https://ban.ggood.vip/SmvB
- Soldering Iron - https://ban.ggood.vip/SmvB
- Rubber Feet -
Amazon
- Class D Audio Amplifier - https://amzn.to/3aF0ZiF
- Circle Cutting Jig - https://amzn.to/3aF0ZiF
- Corner Clamp - https://amzn.to/3aF0ZiF
- Electric Nail Gun - https://amzn.to/3aF0ZiF
- Wood Trimmer - https://amzn.to/3aF0ZiF
- Soldering Iron - https://amzn.to/3aF0ZiF
- Rubber Feet -
Aliexpress
- Circle Cutting Jig - http://bit.ly/38CVXRV
- Corner Clamp - http://bit.ly/38CVXRV
- Electric Nail Gun - http://bit.ly/38CVXRV
- Wood Trimmer - http://bit.ly/38CVXRV
- Soldering Iron - http://bit.ly/38CVXRV
- Rubber Feet -
Note - Please see the images for better understanding
Step 3: Sponsor
Today's Article is Sponsored by lcsc.com
They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
Step 4: Cutting
I used 18mm MDF and used my Table saw Bosch GTS10J to cut it
Dimensions
- 59 x 35.5 cm 2 Pieces up and down Panel
- 59 x 35.5 cm 2 Pieces Side Panel
- 39 x 35.5 cm 2 Pieces Front & Back Panel
- 32 x 35.5 cm 1 piece middle panel
Step 5: Assembly
I used wood glue and corner clamp to hold it
Step 6: Chamber
I used a piece of wood to divide 2 chambers one for amplifier and one for subwoofer
I've installed it 2" deep from the back and used Nails to hold it and then I used wood glue to seal it
Step 7: Front Panel Assembly
I used wood glue and nails to hold it
Step 8: Back Panel Assembly
I used a Jig Saw to cut mounting for the plate amplifier and then used wood glue and nails to hold it
Step 9: Finishing
I used wood filler to fill all the imperfections and then used a sander to finish it up and then used a Round Over bit to round the edges
Step 10: Circle Cutting
I used a circle cutting jig to cut the speaker hole and port hole
Step 11: Panting
I have gone with black and this is a Speaker Cabinet Paint it gives a rough texture I applied it using a paint roller
Note -Please see the images for better understanding
Step 12: Matt Finish
Matt Black looks Fantastic
Step 13: Port
I used a 4.3" dia and 14" Length PVC Pipe and used masking tape to make it a tight fit and then used spray paint to paint it
Step 14: Legs
First, I drilled 4 holes and used 1" rubber legs and then tighten it with some wood screw
Step 15: Wiring
I drilled a hole in the middle chamber for passing speaker wire and then used some glue to seal it
Step 16: Subwoofer Installation
I used a centre punch to mark and then used a drill to make holes for screw and then I used a Spoung tape to make it leak-proof and then tighten up the Subwoofer using 8 Screw
Step 17: Amplifier Installation
I drilled 4 holes for screw and then I plugged the speaker wire to the amplifier and then used 4 screws to tighten it up
Step 18: Finished
- Plug the power wire
- Plug the input wire
- Adjust the controller
- Enjoy
That's all for today guys!
You Just Made It
Thank you for visiting my Instructables Stay tuned for next Projects
