Introduction: DIY Drill Charging Station and Sandpaper Organizer
This drill charging station with sandpaper storage is an easy project that brings some much needed organization to your shop. This project can easily be completed in one day and includes an integrated french cleat system thats simple and strong. I used pocket holes for this project but dados could be used instead with some slight adjustments to the cut list measurements.
CLICK HERE to Download the PDF Plans with Full Cut List
If you like this video please click here to subscribe to my channel!
Also check out my website for more great stuff!
CLICK HERE to Download the PDF Plans with Full Cut list
Tools Used during this build (affiliate):
Step 1: Cut the Pieces From the Cutlist to Size
For this project I’m using 3/4” Baltic birch, which unlike big box store plywood, it comes in 5’ x 5’ sheets. I rough cut the ply into manageable sizes with my circular saw and miter saw then I cut the pieces to final dimension on my table saw. I think this process allows for safer and more accurate cuts on the table saw.
There are 8 pieces needed for this project from 3/4” plywood. For the dimensions of these 8 pieces and a full cut list on this project check out the description section below. You will end up with one large piece for the back, two side pieces, a top and bottom piece, two shelves, and one divider.
Step 2: Cut the French Cleat Backer
After those are cut, set your table saw to cut a 45 degree angle. The large section for the back will be cut in half and this will act as a backer and a French cleat to hang the station once it’s complete.
Step 3: Cut the Dados for the Adjustable Shelving
Now, if you have a Dado stack go ahead and set it up in your table saw to cut dados the width of 1/4” plywood. If you don’t have a Dado stack you can easily make these dados with your regular blade and a series of cuts or with a router and a 1/4” straight bit.
Raise the blade to a 1/4” and set your table saw fence at 2." The dados will be cut on one of the side pieces and on the divider. Select and mark one end on each piece as the bottom. With the end designated as the bottom against the fence cut a Dado on each piece. Then move the table saw fence to 4” and again cut the dados on each piece ensuring that the bottom end is against the fence with each cut. Cut a Dado every 2” until you reach 16”. There should be a total of 8 dados on each piece.
In order for the dados to align correctly after assembly you will need to cut 3/4” off the bottom end of the divider piece. This only needs to be done to the divider piece and not the side piece.
Step 4: Cut the Sections for Drill Storage
Next, you can start laying out the cuts for the drill storage on one of the shelf pieces and mark a line every 2.” If you use the cutlist in the PDF then you will have 8 lines and each section will be 2” wide. Then, mark a line 5” deep the full length of the piece and designate every other section with an X. These are the sections that will need to be cut out.
Using a 2” forstner bit drill a hole at the top of each section. Using a jig saw cut along the lines to the circles to remove the rest of the material. Using a router and a Chamfer bit, make a deep chamfer on the inside edges of the sections. This will help your drills and other tools hang more evenly in place.
A spindle sander makes it easy to clean up the inside edges but this can also be done with some sand paper and hand sanding.
Step 5: Pocket Hole Joinery
Now set your end pieces and two back pieces aside. All of the other pieces will get pocket holes on each end of the piece. I found that three equally spaced per side were plenty.
Step 6: Assemble the Pieces
Place your two side pieces together and mark a line at 18 1/2” from the bottom of both pieces. Now attach your bottom flush with the bottom of the two side and the top with the bottom of the piece at the 18 1/2” mark.
Make sure that the box is square and then mark a line on the top and bottom pieces at 6 1/4” from the outside edge. This will be from the side with the dados. You can now install the divider with the inside edge at the 6 1/4” mark. Make sure to install it with the previously marked bottom end pointing towards the bottom of the box.
Once that’s installed measure and mark lines at 7 1/2” and 11” from the bottom edge of the box. These lines will be marked on the right side of the box and on the divider. With the chamfers pointed towards the top, install the shelf with the cut slots. Alight the bottom of this shelf at the 7 1/2” mark and attach with pocket hole screws.
After that, install the top shelf with bottom of the shelf at the 11” mark. If you place the shelf so that the pocket holes are on the top side it will give you plenty of room for your drill.
Lay the drill station on its face and install the top half of the back with the 45 degree angle in the correct position.
Step 7: Drill a Hole for Plugs
With a forstner bit, drill a hole big enough for the plug of your chargers to fit through, in the side of the drill station. This can be placed wherever on the station that you plan to place your chargers.
Step 8: Hanging the Drill Charging Station
Attach the other half of the back to the wall attaching it with screws in to the studs of the wall. Be sure that this piece is level and that the 45 degree cut is pointed up and in correct position to accept the other other half of the backer that is attached to the drill station. I wanted mine to hang just above this ledge so I just used a scrap piece of plywood as a spacer and made things easy.
Now you can hang your charging station in place securing it with the French cleat backer.
Step 9: Add 1/4" Shelves
I cut the dividers for the sandpaper storage from 1/4” plywood and slide them into place.
Step 10: Fill It Up!!
Now for the part you’ve been waiting for. Simple yet effective storage for your tools and sandpaper!
If you want to see more details on this build you can check out the full build video here:
If you want to see more woodworking and DIY videos please subscribe to my channel
18 Comments
3 years ago on Step 10
Pay for yearly here and you want to charge for the real Instruction? Sorry but when you pay for a website for DYI you should get the whole thing Cut sheet,plans and all. For members you should be able to provide. Sorry if coming off bad just I see more and more of these post makes me want to move on from the site because some of us are just plain noobs and need well "Instructions"
Reply 3 years ago
I understand where your coming from but your membership fee to this site does not benefit me in any way. I paid $175 to have those PDF plans made up so that my followers could get a more detailed idea of the plans. I only charge $5 a download to try and get my money back. If you watch the video closely you can get all the measurements from it and could easily build this project from it alone. The PDF is just an added bonus for those who might need them. I also have 12 other completely free Instructables that took me countless hours to make and none of them benefit me other than reaching new followers. They are there to benefit all of you and possibly help someone try a new project and learn something new.
3 years ago
Thanks for not adding music to your presentation.
Reply 3 years ago
I know music is very subjective so I try to stay away from it.
3 years ago
i love this setup, in thinking in importants of get the same brand and have a correct tool for each works,, nice, good luck
Reply 3 years ago
Thanks friend! It’s nice to have what you need and to be able to find it quickly! I appreciate you taking the time to leave a comment.
3 years ago
Nice work, I like it! I could see these things selling in kit form on Amazon or eBay.
I've been thinking of making a charging station and a sandpaper holder as separate projects. I really like how you made the sand paper rack modular and I'm going to be using your techniques on that.
Due to the remote chance of a lithium fire, I will likely use sheet metal to line the charging station. I've seen battery charging box designs where people use a smoke or fire detector system to sound an alarm and cut power for more safety. A 2 amp fast blow fuse on the AC line would be an easy way to deal with any short circuit power surges.
Reply 3 years ago
Thank you! Extra safety is never a bad thing that’s definitely a good point. Thank you for your input and comment!
Reply 3 years ago
I rethought the battery box concept and people who use those are doing so because they're charging their own home-brew battery packs where that danger is more prevalent. It's probably not an issue with UL listed chargers and packs.
A power strip with a built-in breaker is probably enough protection for power tools like you have in your build.
Reply 3 years ago
Gotcha, yea home brew batteries are definitely something to watch. I just use a good power strip that is mounted on the outside of the organizer with mine.
3 years ago on Introduction
Oh could I use this! But where to put it? All my wall space is taken up with shelves, paintings, photos, notes, etc. Hmmmmm.... (thinking, thinking, thinking...)
Reply 3 years ago
Haha the organization from this is very helpful in a workshop. It’s wide and deep enough to sit on a table or wide shelf as well.
Reply 3 years ago
Thanks for the reply. My "workshop" actually consists of a portion of the walk-in closet in my bathroom because there's nowhere else to store things like tools and nails and screws etc. I might be able to build this and rearrange things. Gotta think about this for a while. Thanks again!
Reply 3 years ago
Gotcha! Well, if you have any questions or need help let me know!
3 years ago
Very cool build. I'll draw inspiration from it for my own charging station
Reply 3 years ago
Awesome!!! Thank you!
3 years ago
I love how organized your whole setup is :)
Reply 3 years ago
Thank you! Organization is always a work in progress! :)
