Introduction: DIY ESP32 Camera Motor Shield - Wifi Camera Robot Car
This article is proudly sponsored by PCBWAY.
PCBWAY make high quality prototyping PCBs for people all over the world. Try it for your self and get 10 PCBs for just $5 at PCBWAY with very great quality, Thanks PCBWAY. The Motor Shield for ESP32-Cam that I developed in this project uses PCBWAY PCB services. In this instructable, I will show you how to build Camera WiFi Robot Car use ESP32-Cam. Let's get started!
Step 1: Design PCB Use Autodesk Eagle Software
To design a PCB use Autodesk Eagle software, which is a CAD program specifically designed for making circuit boards. This software is free for 2-sided boards up to 80cm². This should be more than enough area for any hobby project.You can download Eagle from Autodesk's website, and you will also need to sign up for a free Autodesk account.
To learn how to design a custom printed circuit board for your prototype project. You can follow Circuit Board Design Class.
Step 2: Order PCB on PCBWAY
To make this project you need to order a prototype PCB on PCBWAY. How to order is very easy and you will get 10 Pcs PCB for $5 with very great PCB quality.
Step to Order:
1. SignUp/Log in on pcbway.com
2. Open this PCB project link ESP32 Camera Motor Shield
3. Click Add to cart.
4. Wait moment for PCB review, then Click Check Out.
Step 3: Parts List
Here are the components that you will need to make ESP32 Cam Motor Shield:
- 1 x PCB ESP32-Cam Motor Shield (PCBWAY)
- 1 x ESP32-Cam Board
- 1 x USB to TTL CP2102 Module
- 1 x IC L293D Driver Motor
- 2 x Transistor NPN BC547
- 1 x Voltage Regulator 5V AMS1117
- 1 x Diode 1N4001
- 1 x LED Red 3mm
- 5 x Resistor 10K Ohm
- 2 x Resistor 1K Ohm
- 1 x Capacitor 100uF/16V
- 1 x Active Buzzer 5V
- 1 x Tact Switch
- 1 x SPDT Slide Switch
- 3 x 2 Pin Terminal Block Screw
- 4 x 10 pin Male Header
- 1 x 8 pin Female Header
- 1 x 6 pin Female Header
- 2 x 8 pin Long Legs Female Header
Step 4: Solder SMD Component (AMS1117 5V)
This project has one SMD component, it is not too difficult to solder because the size of the SMD component is quite large, so don't worry.
You will need tweezers as a tool to hold the components when soldered.
Step 5: Place the Components
After finish solder SMD component, next attach other trough hole components on the PCB following the pictures and symbols on the PCB, for details you can follow step by step in the video.
Step 6: Soldering
Solder all the component legs on the back of the PCB, for details you can follow step by step in the video.
After finish solder, cut all the long legs of the component wire
Step 7: Attach Short Leg of the Female Header
Bend the short leg of the female header into an elbow 90 degrees, then attach it on the PCB pin hole as shown. then solder it
Step 8: Attach Long Leg of the Female Header
Bend the long leg of the female header into an elbow 90 degrees. Attach it to other straight long leg of the female header as shown.
Before applying glue, the continuity of each pin is connected first.
Then by using the ESP32-Cam as a mold to hold the pin header, you can solder to the PCB.
Step 9: Attach IC, ESP32-Cam & USB to TTL Module
Install IC L293D (dual motor driver) on the IC socket, see its position do not reverse.
Attach the USB to TTL CP2102 module which already has a male pin header into the female header socket that leads outward.
Install the ESP32-cam board on the female header socket as shown.
Step 10: PCB Mainboard Is Ready
Your PCB mainboard is ready as controller Robot Wifi Camera.
Step 11: Attach Mainboard Into Chassis
You can use a custom chassis that you have or you made yourself. The mainboard PCB is the same shape and size as the Arduino Uno, so you can easily find a chassis that fits this one.
For wheeled motors, it doesn't matter if you use four or two, actually the output of the motor driver is only two, left and right, if you make four wheels, it is only installed in parallel. Connect the left motor and the right motor to the screw terminals on the PCB mainboard motor driver output. Connect 2 x 18650 3.7V batteries to the power source terminal screw on the PCB mainboard.
Step 12: Upload Firmware to ESP32-Cam Board
To make WiFi Camera Robot Car can controlled by smartphone Android, you have to program ESP32-Cam first. The easy way to program ESP32-Cam that you can use this Android App follow this step:
- Install ESP32 Camera WiFi Robot Car from Google Playstore
- Open app, on menu bar select Circuit diagram & Code icon
- Select menu settings, on option Motor Driver to be Used select ESP32-Cam Motor Shield, on option Upload Firmware Via select USB OTG, if you want to connect the WiFi Car with network of router you can set SSID name & Password.Connect ESP32-Cam board to your smartphone use USB OTG adapter.
- To make ESP32-Cam ready to load the program do the holding GPIO0 switch then press resset button.
- The last step click icon upload, and wait moment until completed.
After finish uploaded program, press reset button.
Otherwise, you can program ESP32-Cam board through a computer using the Arduino IDE software use this sketch:
Note: First, your Arduino IDE must be setup to be able use to programming ESP8266 board
Save sketch bellow as "esp32cam_wifi_robot_car_l293d.ino"
#include "esp_camera.h"
#include <WiFi.h>
#include <ArduinoOTA.h>
/* Wifi Crdentials */
//String sta_ssid = "$your_ssid_maximum_32_characters"; // set Wifi network you want to connect to
//String sta_password = "$your_pswd_maximum_32_characters"; // set password for Wifi network
String sta_ssid = "D-Link_DIR-600M"; // set Wifi network you want to connect to
String sta_password = "56781234"; // set password for Wifi network
/* define CAMERA_MODEL_AI_THINKER */
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
/* Defining motor and servo pins */
extern int DRV_A = 12;
extern int DRV_B = 13;
extern int DIR_A = 14;
extern int DIR_B = 15;
extern int ledVal = 20; // setting bright of flash LED 0-255
extern int ledPin = 4; // set digital pin GPIO4 as LED pin (use biult-in LED)
extern int buzzerPin = 2; // set digital pin GPIO2 as LED pin (use Active Buzzer)
extern int servoPin = 2; // set digital pin GPIO2 as servo pin (use SG90)
unsigned long previousMillis = 0;
void startCameraServer();
void initServo() {
ledcSetup(8, 50, 16); /*50 hz PWM, 16-bit resolution and range from 3250 to 6500 */
ledcAttachPin(servoPin, 8);
void initLed() {
ledcSetup(7, 5000, 8); /* 5000 hz PWM, 8-bit resolution and range from 0 to 255 */
ledcAttachPin(ledPin, 7);
void setup() {
Serial.begin(115200); // set up seriamonitor at 115200 bps
Serial.setDebugOutput(true);
Serial.println();
Serial.println("*ESP32 Camera Remote Control - L293D Bluino Shield*");
Serial.println("--------------------------------------------------------");
// Set all the motor control pin to Output
pinMode(DRV_A, OUTPUT);
pinMode(DRV_B, OUTPUT);
pinMode(DIR_A, OUTPUT);
pinMode(DIR_B, OUTPUT);
pinMode(ledPin, OUTPUT); // set the LED pin as an Output
pinMode(buzzerPin, OUTPUT); // set the buzzer pin as an Output
pinMode(servoPin, OUTPUT); // set the servo pin as an Output
// Initial state - turn off motors, LED & buzzer
digitalWrite(DRV_A, LOW);
digitalWrite(DRV_B, LOW);
digitalWrite(DIR_A, LOW);
digitalWrite(DIR_B, LOW);
digitalWrite(ledPin, LOW);
digitalWrite(buzzerPin, LOW);
digitalWrite(servoPin, LOW);
/* Initializing Servo and LED */
initServo();
initLed();
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
} else {
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
//drop down frame size for higher initial frame rate
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_QVGA);
// Set NodeMCU Wifi hostname based on chip mac address
char chip_id[15];
snprintf(chip_id, 15, "%04X", (uint16_t)(ESP.getEfuseMac()>>32));
String hostname = "esp32cam-" + String(chip_id);
Serial.println();
Serial.println("Hostname: "+hostname);
// first, set NodeMCU as STA mode to connect with a Wifi network
WiFi.mode(WIFI_STA);
WiFi.begin(sta_ssid.c_str(), sta_password.c_str());
Serial.println("");
Serial.print("Connecting to: ");
Serial.println(sta_ssid);
Serial.print("Password: ");
Serial.println(sta_password);
// try to connect with Wifi network about 10 seconds
unsigned long currentMillis = millis();
previousMillis = currentMillis;
while (WiFi.status() != WL_CONNECTED && currentMillis - previousMillis <= 10000) {
delay(500);
Serial.print(".");
// if failed to connect with Wifi network set NodeMCU as AP mode
IPAddress myIP;
if (WiFi.status() == WL_CONNECTED) {
Serial.println("");
Serial.println("*WiFi-STA-Mode*");
Serial.print("IP: ");
myIP=WiFi.localIP();
Serial.println(myIP);
delay(2000);
} else {
WiFi.mode(WIFI_AP);
WiFi.softAP(hostname.c_str());
myIP = WiFi.softAPIP();
Serial.println("");
Serial.println("WiFi failed connected to " + sta_ssid);
Serial.println("");
Serial.println("*WiFi-AP-Mode*");
Serial.print("AP IP address: ");
delay(2000);
// Start camera server to get realtime view
Serial.print("Camera Ready! Use 'http://");
Serial.print(myIP);
Serial.println("' to connect ");
ArduinoOTA.begin(); // enable to receive update/upload firmware via Wifi OTA
void loop() {
// put your main code here, to run repeatedly:
ArduinoOTA.handle();
}Save sketch bellow as "app_httpd.cpp"
#include "esp_http_server.h"
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
/* Initializing pins */
extern int DRV_A;
extern int DRV_B;
extern int DIR_A;
extern int DIR_B;
extern int ledPin;
extern int buzzerPin;
extern int servoPin;
extern int ledVal;
typedef struct {
httpd_req_t *req;
size_t len;
} jpg_chunking_t;
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t stream_httpd = NULL;
httpd_handle_t camera_httpd = NULL;
static size_t jpg_encode_stream(void * arg, size_t index, const void* data, size_t len){
jpg_chunking_t *j = (jpg_chunking_t *)arg;
if(!index){
j->len = 0;
if(httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK){
return 0;
j->len += len;
return len;
static esp_err_t capture_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
int64_t fr_start = esp_timer_get_time();
fb = esp_camera_fb_get();
if (!fb) {
Serial.printf("Camera capture failed");
httpd_resp_send_500(req);
return ESP_FAIL;
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
size_t fb_len = 0;
if(fb->format == PIXFORMAT_JPEG){
fb_len = fb->len;
res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
} else {
jpg_chunking_t jchunk = {req, 0};
res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk)?ESP_OK:ESP_FAIL;
httpd_resp_send_chunk(req, NULL, 0);
fb_len = jchunk.len;
esp_camera_fb_return(fb);
int64_t fr_end = esp_timer_get_time();
Serial.printf("JPG: %uB %ums", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
return res;
static esp_err_t stream_handler(httpd_req_t *req){
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
static int64_t last_frame = 0;
if(!last_frame) {
last_frame = esp_timer_get_time();
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
return res;
while(true){
if (!fb) {
res = ESP_FAIL;
} else {
if(fb->format != PIXFORMAT_JPEG){
bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
fb = NULL;
if(!jpeg_converted){
Serial.printf("JPEG compression failed");
res = ESP_FAIL;
} else {
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
if(res == ESP_OK){
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
if(fb){
fb = NULL;
_jpg_buf = NULL;
} else if(_jpg_buf){
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
int64_t frame_time = fr_end - last_frame;
last_frame = fr_end;
frame_time /= 1000;
last_frame = 0;
return res;
static esp_err_t cmd_handler(httpd_req_t *req){
char* buf;
size_t buf_len;
char variable[32] = {0,};
char value[32] = {0,};
buf_len = httpd_req_get_url_query_len(req) + 1;
if (buf_len > 1) {
buf = (char*)malloc(buf_len);
Serial.println(buf);
if(!buf){
return ESP_FAIL;
if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
if (httpd_query_key_value(buf, "var", variable, sizeof(variable)) == ESP_OK &&
httpd_query_key_value(buf, "val", value, sizeof(value)) == ESP_OK) {
} else {
free(buf);
httpd_resp_send_404(req);
return ESP_FAIL;
} else {
free(buf);
return ESP_FAIL;
free(buf);
} else {
Serial.println(ESP_FAIL);
return ESP_FAIL;
int val = atoi(value);
int res = 0;
if(!strcmp(variable, "framesize")) {
if(s->pixformat == PIXFORMAT_JPEG) res = s->set_framesize(s, (framesize_t)val);
else if(!strcmp(variable, "quality")) res = s->set_quality(s, val);
else if(!strcmp(variable, "contrast")) res = s->set_contrast(s, val);
else if(!strcmp(variable, "brightness")) res = s->set_brightness(s, val);
else if(!strcmp(variable, "saturation")) res = s->set_saturation(s, val);
else if(!strcmp(variable, "gainceiling")) res = s->set_gainceiling(s, (gainceiling_t)val);
else if(!strcmp(variable, "colorbar")) res = s->set_colorbar(s, val);
else if(!strcmp(variable, "awb")) res = s->set_whitebal(s, val);
else if(!strcmp(variable, "agc")) res = s->set_gain_ctrl(s, val);
else if(!strcmp(variable, "aec")) res = s->set_exposure_ctrl(s, val);
else if(!strcmp(variable, "hmirror")) res = s->set_hmirror(s, val);
else if(!strcmp(variable, "vflip")) res = s->set_vflip(s, val);
else if(!strcmp(variable, "awb_gain")) res = s->set_awb_gain(s, val);
else if(!strcmp(variable, "agc_gain")) res = s->set_agc_gain(s, val);
else if(!strcmp(variable, "aec_value")) res = s->set_aec_value(s, val);
else if(!strcmp(variable, "aec2")) res = s->set_aec2(s, val);
else if(!strcmp(variable, "dcw")) res = s->set_dcw(s, val);
else if(!strcmp(variable, "bpc")) res = s->set_bpc(s, val);
else if(!strcmp(variable, "wpc")) res = s->set_wpc(s, val);
else if(!strcmp(variable, "raw_gma")) res = s->set_raw_gma(s, val);
else if(!strcmp(variable, "lenc")) res = s->set_lenc(s, val);
else if(!strcmp(variable, "special_effect")) res = s->set_special_effect(s, val);
else if(!strcmp(variable, "wb_mode")) res = s->set_wb_mode(s, val);
else if(!strcmp(variable, "ae_level")) res = s->set_ae_level(s, val);
else {
res = -1;
if(res){
return httpd_resp_send_500(req);
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
return httpd_resp_send(req, NULL, 0);
static esp_err_t status_handler(httpd_req_t *req){
static char json_response[1024];
char * p = json_response;
*p++ = '{';
p+=sprintf(p, "\"framesize\":%u,", s->status.framesize);
p+=sprintf(p, "\"quality\":%u,", s->status.quality);
p+=sprintf(p, "\"brightness\":%d,", s->status.brightness);
p+=sprintf(p, "\"contrast\":%d,", s->status.contrast);
p+=sprintf(p, "\"saturation\":%d,", s->status.saturation);
p+=sprintf(p, "\"special_effect\":%u,", s->status.special_effect);
p+=sprintf(p, "\"wb_mode\":%u,", s->status.wb_mode);
p+=sprintf(p, "\"awb\":%u,", s->status.awb);
p+=sprintf(p, "\"awb_gain\":%u,", s->status.awb_gain);
p+=sprintf(p, "\"aec\":%u,", s->status.aec);
p+=sprintf(p, "\"aec2\":%u,", s->status.aec2);
p+=sprintf(p, "\"ae_level\":%d,", s->status.ae_level);
p+=sprintf(p, "\"aec_value\":%u,", s->status.aec_value);
p+=sprintf(p, "\"agc\":%u,", s->status.agc);
p+=sprintf(p, "\"agc_gain\":%u,", s->status.agc_gain);
p+=sprintf(p, "\"gainceiling\":%u,", s->status.gainceiling);
p+=sprintf(p, "\"bpc\":%u,", s->status.bpc);
p+=sprintf(p, "\"wpc\":%u,", s->status.wpc);
p+=sprintf(p, "\"raw_gma\":%u,", s->status.raw_gma);
p+=sprintf(p, "\"lenc\":%u,", s->status.lenc);
p+=sprintf(p, "\"hmirror\":%u,", s->status.hmirror);
p+=sprintf(p, "\"dcw\":%u,", s->status.dcw);
p+=sprintf(p, "\"colorbar\":%u", s->status.colorbar);
*p++ = '}';
*p++ = 0;
httpd_resp_set_type(req, "application/json");
return httpd_resp_send(req, json_response, strlen(json_response));
static esp_err_t state_handler(httpd_req_t *req){
char* buf;
size_t buf_len;
char cmd[32] = {0,};
if (buf_len > 1) {
if(!buf){
return ESP_FAIL;
if (httpd_query_key_value(buf, "cmd", cmd, sizeof(cmd)) == ESP_OK) {
} else {
free(buf);
Serial.print("*");
return ESP_FAIL;
} else {
free(buf);
Serial.print("**");
return ESP_FAIL;
free(buf);
} else {
Serial.print("***");
return ESP_FAIL;
int res = 0;
if(!strcmp(cmd, "F")) {
Serial.println("Forward");
digitalWrite(DRV_A, HIGH);
digitalWrite(DRV_B, HIGH);
digitalWrite(DIR_A, HIGH);
digitalWrite(DIR_B, HIGH);
httpd_resp_set_type(req, "text/html");
return httpd_resp_send(req, "OK", 2);
else if(!strcmp(cmd, "B")) {
Serial.println("Backward");
else if(!strcmp(cmd, "R")) {
Serial.println("Turn Right");
else if(!strcmp(cmd, "L")) {
Serial.println("Turn Left");
else if(!strcmp(cmd, "G")) {
Serial.println("Forward Left");
else if(!strcmp(cmd, "H")) {
Serial.println("Backward Left");
else if(!strcmp(cmd, "I")) {
Serial.println("Forward Right");
else if(!strcmp(cmd, "J")) {
Serial.println("Backward Right");
else if(!strcmp(cmd, "S")) {
Serial.println("Stop");
else if(!strcmp(cmd, "V")) {
Serial.println("Horn On");
digitalWrite(buzzerPin, HIGH);
else if(!strcmp(cmd, "v")) {
Serial.println("Horn Off");
else if(!strcmp(cmd, "W")) {
Serial.println("LED On");
ledcWrite(7, ledVal);
else if(!strcmp(cmd, "w")) {
Serial.println("LED Off");
ledcWrite(7, 0);
else if (!strcmp(cmd, "x")){
Serial.println("Flash Light : Low (20)");
ledVal = 20;
else if (!strcmp(cmd, "y")){
Serial.println("Flash Light : Medium (50)");
ledVal = 50;
else if (!strcmp(cmd, "z")){
Serial.println("Flash Light : Bright (100)");
ledVal = 100;
else if (!strcmp(cmd, "Z")){
Serial.println("Flash Light : Super Bright (255)");
ledVal = 255;
/* Controlling the servo motor angle with PWM */
/* ledcWrite(Channel, Dutycycle) dutycycle range : 3250-6500*/
else if (!strcmp(cmd, "0")){
Serial.println("Servo 0 (3250)");
ledcWrite(8, 3250);
else if (!strcmp(cmd, "1")){
Serial.println("Servo 1 (3575)");
ledcWrite(8, 3575);
else if (!strcmp(cmd, "2")){
Serial.println("Servo 2 (3900)");
ledcWrite(8, 3900);
else if (!strcmp(cmd, "3")){
Serial.println("Servo 3 (4225)");
ledcWrite(8, 4225);
else if (!strcmp(cmd, "4")){
Serial.println("Servo 4 (4550)");
ledcWrite(8, 4550);
else if (!strcmp(cmd, "5")){
Serial.println("Servo 5 (4875)");
ledcWrite(8, 4875);
else if (!strcmp(cmd, "6")){
Serial.println("Servo 6 (5200)");
ledcWrite(8, 5200);
else if (!strcmp(cmd, "7")){
Serial.println("Servo 7 (5525)");
ledcWrite(8, 5525);
else if (!strcmp(cmd, "8")){
Serial.println("Servo 8 (5850)");
ledcWrite(8, 5850);
else if (!strcmp(cmd, "9")){
Serial.println("Servo 9 (6175)");
ledcWrite(8, 6175);
else if (!strcmp(cmd, "q")){
Serial.println("Servo q (6500)");
ledcWrite(8, 6500);
else {
res = -1;
if(res){
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
httpd_uri_t status_uri = {
.uri = "/status",
.method = HTTP_GET,
.handler = status_handler,
.user_ctx = NULL
httpd_uri_t cmd_uri = {
.uri = "/control",
.method = HTTP_GET,
.handler = cmd_handler,
.user_ctx = NULL
httpd_uri_t capture_uri = {
.uri = "/capture",
.method = HTTP_GET,
.handler = capture_handler,
.user_ctx = NULL
httpd_uri_t stream_uri = {
.uri = "/stream",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
httpd_uri_t state_uri = {
.uri = "/state",
.method = HTTP_GET,
.handler = state_handler,
.user_ctx = NULL
Serial.printf("Starting web server on port: '%d'", config.server_port);
if (httpd_start(&camera_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(camera_httpd, &cmd_uri);
httpd_register_uri_handler(camera_httpd, &capture_uri);
httpd_register_uri_handler(camera_httpd, &status_uri);
httpd_register_uri_handler(camera_httpd, &state_uri);
config.server_port += 1;
config.ctrl_port += 1;
Serial.printf("Starting stream server on port: '%d'", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &stream_uri);
Step 13: Let's Play
The WiFi robot can be controlled via the Android app in two ways, controlled directly from android to ESP32-Cam (AP mode), connect android to SSID of ESP32-Cam then set ip address on app 192.168.4.1.
Other way is ESP32-Cam (STA mode), android is connected to the same router network then set the IP address on app according to the IP address that is owned by ESP32-Cam(i.e. 192.168.0.2).
