DIY Experiment: Embossing Concrete Challenge
Intro: DIY Experiment: Embossing Concrete Challenge
Check out the the short video I made of this DIY challenge above.
This DIY was born out of a curiosity to see if I could emboss cement. Using only the materials I had around - which ended up being cardboard. This could of been done better and easier with a 3D printer or a CNC cutter - but I had cardboard.
For more pictures have a look at my blog post here: Home Tree Atlas
STEP 1: Materials
All you need for this project is:
- A bag of concrete
- Cardboard
- An exacto knife
- And a design that you want to use
STEP 2: The Template
The first step is to print out your design and cut it out. Then trace it onto a sheet of cardboard. I did this twice because I wanted a thick mold for the concrete to pour into.
STEP 3: Save the Scrap Pieces
You can save the scrap pieces of the template you just cut out. I went and made this stool, using the cardboard cutouts as a mold for the white cement inlay. You can see the project here.
STEP 4: Waterproofing
The next step is to waterproof the card. This is done by covering it with tape.
After you've done that, you'll want to add a backing piece, again covered in tape
STEP 5: Building the Box
Next cut out strips for the sides of the box, cover them with tape and put the box together.
In the pictures you can see I made some T shaped stripes. These are stuck to the sides of the box to brace it. Otherwise, when you pour in the cement the sides will bulge out.
STEP 6: Start Pouring
Mix up your cement and pour it in. You'll want a bit of a wet mix.
Tap and shake the box gently to get the air bubbles out.
STEP 7: The Reveal
Let everything dry for 20+ hours. Then cut the cardboard off.
STEP 8:
Check out my blog for more weird DIY projects: The Mill @ Home Tree Atlas
3 Comments
numbanine 8 years ago
Chesshaus 8 years ago
looks like something that I would like to try. I think that I would do something realy simple to see if I can do it.
flyingpuppy 8 years ago
