Introduction: DIY Extreme Bright USB LED | LifeHack
Hey! everyone My name is Steve .
Today i'm going to show you How to Make Extreme Bright USB LED .
I'm using a 10 watt LED chip .
Click Here to See The Video
Let's Start
Step 1: Stuff I Used
10 Watt LED : It is very small but it can Produce Tremendous amount of light
Dc To Dc Converter : It is used to Convert 5V Dc coming from USB to 9V to Drive the LED
Aluminum Sheet : It is used to Cool Down the led " it's a Heatsink "
Step 2: Attention
i'm using a Very Small Heat Sink
So i'm not going to Drive the Led to it's maximum Power
If you Just Set The Voltage to 9V it's just work fine with little warm up
Step 3: Drilling
- Drill 2 Hole in Center
- Keep 3 mm Distance between 2 Holes
Step 4: Converter Mounting
- Cut Double Sided Tape matching the Dc to Dc converter Length
- Now Stick the tape to Aluminium Sheet ( As Shown in The Picture )
- Now Stick the Dc to Dc Converter on the Tape
- And Remove the excess Tape from the Aluminium Sheet
Step 5: The Solder
- Now Solder The USB wire to Converter
Connection
- Negative USB wire to VIN-
- Positive USB wire to VIN+
If Don't Know Negative & Positive
- Use Your Multi-meter to Find the Wire
- Normally it have 4 wire
- White , Green , Red , Black
- Black is your Negative
- Red is Your Positive
All The Best
Step 6: Secure the USB Wire
- Use a Cable ties to Secure USB wire with 2 Holes
Step 7: Converter Set Up
- Use your Multi meter and a Screw drive to set the Potentiometer
- Connect your Multi-meter positive lead to OUT+
- Connect your Multi-meter negative lead to OUT-
- Now use your screw driver to tune the Potentiometer
- Set The Voltage Close to 9 V ( Necessary )
Step 8: Mounting the LED
- Use some glue to glue the led you can also use silicone based glue
- Now Connect 2 Wire To Led
- Negative of Led to OUT-
- Positive of Led to OUT+
- Just Connect two wire to any terminal of the led
- now connect your USB to any Source
- If it Turn On . You've connected The right way
- if It Does not Turn On . You've connected The wrong way
- Just Flip the Connection
All The Best
Step 9: Congratulation
You Just Made It
Now Enjoy Your LED
Thank you for visiting my Instructables
Stay tuned for next Projects
