Introduction: DIY Eyeshadow Palette
This is an instruction set for a DIY eye shadow palette
**Be sure to wear tattered or old clothing, it gets messy!**
**Be sure to cover work area before using Mica Powders**
**Always wear gloves when handling alcohol and Mica Powders**
Step 1:
Step 2: Overview of Products Used
- Pigmented mica powders (Can be purchased at arts and crafts store)
- Empty eye shadow palette
- Double-sided eye shadow brush
- High absorbency rubbing alcohol
- Felt pads
- Aluminum foil
- Chalk
- Spray Bottle
- Latex gloves
Step 3: Preparing the Palette
Apply gloves and make sure palette is wiped clean.
Take almond oil and squeeze two drops into the space being used for your first color.
Start with two drops, but use number of drops needed to entirely cover the desired space in the empty palette
Step 4: Pouring Mica Powder
Choose desired color of mica powder
Take one teaspoon (or half a table spoon depending on supplies used) of mica powder and pour it into palette
Step 5: Wipe Away Excess Powder
Take a piece of paper or paper towel and place it under palette
Using one of your fingers, wipe away excess mica powder allowing powder to fall onto the piece of paper
Pour excess mica powder back into it's original container
Step 6: Prepare Chalk
Using your hands, break chalk into small pieces
Begin lightly tapping the chalk with a hammer (or desired household item) until the chalk is a fine powder.
Set chalk aside until it is ready for use
The chalk serves as a powder binder, which helps to keep your mica powders compacted until you begin the drying process
Step 7: Use Chalk As a Powder Binder
Take a pinch of chalk and sprinkle it on top of the mica powder.
Using the double-sided eye shadow brush, mix chalk and mica powder together until the chalk is no longer visible in the mix
Step 8: Cover Felt Pad in Aluminum Foil
Rip a piece of aluminum foil that can cover all sides of the felt pad
Place felt pad on top of aluminum foil
Wrap the aluminum foil around the felt pad until all sides are covered
Take the top of the excess foil and twist it until the felt pad is tightly concealed in the foil
Step 9: Firmly Press Powder Mix Into Palette
Take felt pad covered in aluminum foil and begin to firmly press down on the powder mix
This will aid you in keeping the powder compacted until you start the drying process.
Step 10: Spray Alcohol Onto Powder Mix
Pour high absorbency alcohol into the empty spray bottle.
Be sure that the nozzle on the spray bottle is turned to the mist setting ( if applicable, most spray bottles only have one setting).
Spray the alcohol onto the powder mix until the top of the mix is damp.
The alcohol works as a liquid binder to keep your powder mix compacted and allows it to dry quickly.
Step 11: Press Powder With Foil-covered Felt Pad Again
Use a felt pad covered in aluminum foil to press the powder mix one last time
Be sure to press powder until the entire mix is flat and even
Step 12: Spray Alcohol Onto Pressed Powder Mix Again
Spray alcohol onto powder mix
Use a damp paper towel to wipe away any undesired powder on the palette
Leave to dry for 3 hours
Once dry, the eye shadow is ready to use!
Step 13: Finished Product
This is the finished product for a full eye shadow palette featuring four colors
Repeat ALL steps to create another color in your palette, substitute for desired color when completing Step 2.
