DIY FIXIE - Fixed Gear, Trackbike Frame..
66,864
46
31
Introduction: DIY FIXIE - Fixed Gear, Trackbike Frame..
This is my simple way of making the frame for my fixed gear trackbike frame..
made from an old road bike, cut up and welded back in the right geometry..
Step 1: Cut Up
cut off drop outs, and the rear wheel tubes..
Step 2: 1st Welding
the first welding is the tubes in a alightly more open angle so the dropouts is lowered 2-3 cm from their original height..
Step 3: Cut Up
cut the top tubes connecting the droputs to the saddle tube..
Step 4: Make New Droputs
the to droputs for the rear wheel a made out of 3mm thick steel plate, remember to make them both accurate and similar. the backdrop droputs are use to tighten the chain moving the rear wheel backwards..
Step 5: 2nd Welding
the dropouts are welded on the lower tubes.
very important the droputs must be be welded in the same hight and angle, or else your rear wheel wont run straight..
Step 6: 3rd Welding - Changing the Fork Angle
the steering angle of the fork is smaller on a trackbike than an roadbike. citybikes are sometimes even more wider and large angels.. but this angle must be smaller but off course not too small otherwise the fornt wheel will be hitting your Pedals/feet when cycling (+..+)
remove the paint and cut up the fron fork tube
Step 7: End of Frame Work..
when done with welding the front tube, try out your new fixie /*0*\
Be the First to Share
    • Fandom Contest
      Fandom Contest
    • Teach With Tinkercad Contest
    • Metal Contest
      Metal Contest
    31 Comments
    dlu
    dlu
    9 years ago on Step 4
    Did you heat treat the droput or do anything on it?
    jonasedvard
    jonasedvard
    Reply 9 years ago on Step 4
    the whole bike is left without any treatment for about a year. a natural protection occurs on the surface of the metal. oxidation/rust is a way to treat any metal. brass copper etc.
    i gave the bike lin-oil and beewax to give the metal af final shine and color control.
    uziXwraith
    uziXwraith
    10 years ago on Step 2
    Couldnt you just bend the bottom tubes instead of hacking them off at the bottom bracket?, when i converted my roadbike, i didnt see much difference from say, a BIANCHI which is barely track geom. anyway .i dont really think you need to keep geometry if you arent racing, or some other professional application. i was a messenger for a year on my road conversion, never clicked cranks, never ran into any problems, i had more problems messengering on my fuji track... bottom bracket spat out my non drive crank in the middle of downtown chicago, had to bang it back on with my ulock, and tighten down the hex again. garbage.
    Necronomicog
    Necronomicog
    10 years ago on Introduction
    Chain tensioners do work. Why else would Raleigh's Rush Hour and other bike company's use them.
    mrdepo96
    mrdepo96
    12 years ago on Introduction
     pretty complicated, you could just use a chain tensioner or something similar. BUT!
    The work you did was amazing and now it looks like it was made for the track :)
    carpe_noctem
    carpe_noctem
    Reply 12 years ago on Introduction
    chain tensioners don't work for fixed gear. See sheldon brown. com (org?) for more info. his wheels would have worked just fine, i have done 2 fixie conversions, one from an old 70's huffy tenspeed frame, another from a soviet-made road bike (штарт шоссе,i moved to russia). while steeper frame angles will create a more "track bike" feel and more responsiveness in traffic, i have had no problems in my 3 years of riding my conversions. The main prequisite is horizontal (or nearly) dropouts, (or fork ends) which allow you to get adequate chain tension. Also notable is that i have spent no more than 150 dollars on both. for all the kiddies at home, this is definitely do-able. dumpster dive or hit up craiglist for parts, but i got lucky with my rear wheel.
    Furball_Fidelis
    Furball_Fidelis
    but then why do chain tensioners work on SS Dirt jump bikes?
    Same concept isn't it? just a fixie has a less robust frame and bigger wheels
    jonasedvard
    jonasedvard
    agree! DUMPSTERdiving is tha thing to do! a lot of old parts can be used to give it that retro feeling, but dont use old chains, cables/wires, tires/tubes, etc.
    carpe_noctem
    carpe_noctem
    Reply 11 years ago on Introduction
    I use old tires too, but performance probably suffers considerably. If it looks like you can use it, use it until it stops working. Chains are the main no-no here. A new chain makes a huge difference and is relatively inexpensive as well.
    BtheBike
    BtheBike
    I learned to refurb a rusted prewar skip tooth chain . Since then I always refurb them unless they are "stretched" . The same goes for cables ,and tubes too . Maybe I'll post a chain refurb tutorial.
    jonasedvard
    jonasedvard
    chain tension is importent, but a tensioner isn't a strong enough.
    my project concerns bicycle geometry! thank you 4 the shout
    BtheBike
    BtheBike
    Really ambitious ! I love the look of raw steel frames. Great Tute
    filbone
    filbone
    just wondering will all these frame modification, is the bike still safe to ride? would you recommend fillet brazing instead of welding if welding not available?
    happysadman54321
    happysadman54321
    12 years ago on Step 4
    what do u use to cut the steel and can you braze the dropouts on?
    jonasedvard
    jonasedvard
    normal hacksaw, dont need to braze, more easier to mig the whole thing, brazing is only for when you work with lugs!
    happysadman54321
    happysadman54321
    i ment cutting the dropouts
    but is it possible to braze the droupouts?
    cuz my dad already has a blowtorch and i just want to switch out the dropouts cuz mine are vertical
    jonasedvard
    jonasedvard
    cutting the dropouts with hacksaw, mig weld the dropouts!
    don't braze the dropouts unless you're using dropouts that fit with your chainstay, these two things has to fit together if not the brazing cannot be done, brazing depends on two clean sufaces to work
    happysadman54321
    happysadman54321
    Reply 12 years ago on Step 4
    thanx
    well i cant afford a welder so ill jst look for a different frame
    jambamkin
    jambamkin
    12 years ago on Step 7
    Wow I thought this was gunna be "take off the cassette, add a fixed gear, et voila" this is much more impressive and shows how geometry is important to the use of a bike.
