Introduction: Fixing a Old Broken Computer Cooling Fan With a New DC Motor
In this project i will show you how to fix a broken computer fan with a new fan.
I found this computer fan in my junk collection, which was not working. I tried to repair the fan with the same motor but no use, the chip which controls the motor was fried so came up with this Idea of using a new motor.
Step 1: Making Video
You can watch the video of fixing the fan or continue reading for the steps involved.
You Can Subscribe To My YouTube Channel Here : https://goo.gl/ctc8l9
Step 2: Things Required
1. Broken Computer Fan (Fan & enclosure separated)
2. Hot Glue Gun
3. DC motor (capable of running between 5 to 12 volt)
4. USB Cable
5. Remote Button (found this in my junk collection)
6. Deo bottle cap
7. Any container cap (diameter 10Cm)
8. soldering rod, soldering wire & soldering paste
9. Stripper
10. Scissor
11. Super Glue
12. Battery & Battery cap with clips
If you interested in making this product you can use my affiliate buying links :
Amazon US:
Computer cooling fan : http://amzn.to/2acNUk6
Hot Glue Gun - http://amzn.to/29Y2BU8
DC Motor : http://amzn.to/29Qg9lO
USB Cable - http://amzn.to/2a3wlCS
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
Scissor - http://amzn.to/29Y1K65
Super glue - http://amzn.to/29Wvpi1
Wire Stripper & Cutter - http://amzn.to/29RBsm8
Amazon India :
Computer Cooling Fan - http://amzn.to/2a0r3sq
Hot Glue Gun - http://amzn.to/29HEslT
DC Motor - http://amzn.to/29X8X79
USB Cable - http://amzn.to/2a5dCWj
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
Scissor - http://amzn.to/29P2ECE
Super glue - http://amzn.to/29HHbvK
Wire Stripper & Cutter - http://amzn.to/2a0wBD8
Step 3: Motor Attachement
1st Image - Make a hole in the center of the container cap so that motor shaft can pass through
2nd image - Glue the motor to the container cap
Step 4: Motor Cap
1st Image - Make a hole in the center of the Deo bottle cap
2nd Image - Insert the USB wire through the hole.
3rd image - Solder the wire to the motor and glue the cap over the motor
4th Image - USB pin configuration
Step 5: Fan Attachement
1st Image - Make a hole in the center of the fan bade
2nd Image - Insert the remote button and glue it
Step 6: Combining the Motor, Fan Blade & the Outer Cover
1st Image - Attach the fan and the motor
2nd Image - Make some holes in the container cap so that air can flow
3rd Image - Mark the outline of the outer cover on the container cap
4th image - after marking cut the excess with a scissor
5th Image - Glue the container cap to the outer cover (be very careful while gluing make sure the blades are not touching the outer cover
Step 7: Finished Images
To the watch the video of the testing please go to the step 1 or CLICK HERE
Testing Begins @ 7:03
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US:
Amazon India :
Follow & Subscribe Me On for more Cool Projects :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
Instagram : https://www.instagram.com/makestuff_ms/
Google Plus : https://goo.gl/RpTnwf
Facebook : https://www.facebook.com/makestuffMS
Also please do read or watch my other instructables
THANK YOU FOR READING !!!
