DIY "Floating" Night Lamp
Intro: DIY "Floating" Night Lamp
In my first DIY build Instructable, I am going to show how you can build simple design floating night lamp, which is easy to build and doesn’t require any advanced tools.
EQUIPMENT YOU'LL NEED:
- Jigsaw
- Clamp
- Drill
- Hot glue gun
- Wood glue
- Square ruler
- Ruler
- Paint brush
- 80-120 and 220 grit sandpapers
- Scissors
MATERIALS YOU'LL NEED:
- 1.5 x 1.5 cm wood board ~210 cm length
- 3 x 3 cm wood board ~60 cm length
- LED Filament bulb 7W Warm White color ~700 Lumen
- Bulb socket
- Power cord with On / Off switch
- Paint
- Double side tape
- A4 paper / color paper / binders
Like what I do? Consider becoming a PATRON! This is a great way to support my work and get extra benefits! https://www.patreon.com/DIYPerspective
STEP 1: Parts You Need to Cut From Wood Boards
Wood parts:
- 8 pieces 1.5 x 1.5 cm x 13 cm
- 3 pieces 1.5 x 1.5 cm x 25 cm
- 1 pieces 1.5 x 1.5 cm x 23 cm
- 4 pieces 3 x 3 cm x 12 cm
STEP 2: Gluing First Part
Glue two 25 cm length pieces with two 13 cm length pieces. Hold pieces for 3-5 minutes while using hair dryer to speed up glue drying process.
STEP 3: Gluing Second Part
Glue 23 cm and 25 cm pieces with two 13 cm pieces. Hold pieces for 3-5 minutes while using hair dryer to speed up glue drying process.
STEP 4: Gluing Base for the Lamp
Glue four 12 cm pieces and clamp them. Wait 20-24 hours until wood glue on all parts completely dry up.
STEP 5: Connecting Glued Lamp Parts
Glue lamp's frame parts with last four 13 cm pieces.
STEP 6: Pressing and Waiting
Add something heavier to press all four corners of the lamp. Wait 20-24 hours until glue completely dry up.
STEP 7: Drilling
Drill a hole for the power cable at the back of a lamp (near 23 cm piece).
STEP 8: Sanding
First sand rough spots and corners with 80 grit sandpaper and then sand everything with finer 220 grit sandpaper.
STEP 9: Marking Gluing Spot
Mark gluing spot for the lamp's frame. Lamp's frame should be 3 cm from the lamp's base edges.
STEP 10: Connecting Frame to Base
Add glue on the marked spot, place lamp's frame on the base and press it down with something heavier. You should wait 20-24 hours until glue completely dry up.
STEP 11: Painting
I am using white water based paint to paint the lamp. They has almost no bad smell so you can paint inside at your home.
STEP 12: Routing Cable
Route the power cable through the hole and assemble bulb socket. Test it, before next step. I am using E27 T210 bulb socket type which connects to AC (120-250v) power from the wall.
STEP 13: Hot Gluing Cable
Hot glue around the cable, that you couldn't pull it out by an accident.
STEP 14: Hot Gluing Bulb Socket
Put hot glue on the bottom of the bulb socket and quickly press it down on the lamp's base.
STEP 15: Adding More Hot Glue
Add more hot glue around the bulb socket for firm bond.
STEP 16: Cutting Paper Pieces
Cut two 12.5 cm x 24 cm double side orange paper pieces. Put some double side tape on the paper ends.
STEP 17: Placing Paper
Place the paper pieces that those would be the same distance from lamp's left and right edges.
STEP 18: A4 Paper
Add some double side tape on the A4 paper.
STEP 19: Gluing A4 Paper
Glue A4 paper to the backside of the lamp.
STEP 20: Cutting Legs for the Lamp
Place some double side tape on any rubber you have and cut four legs for the lamp's base.
STEP 21: Gluing Legs
Glue all four legs to the lamp's base. Try to glue as close as possible to the lamp's base edges for the best stability.
STEP 22: Choosing Right Bulb
First I was using standard 14W led bulb, but it was too bright, so I changed it to 7W led filament bulb warm white color. It gave way more beautiful colors at night.
STEP 23: Other Materials You Could Use
If you don't like using paper and want more robust material, you could use back side of the binders. They are cheap, has nice texture and come in variety of colors.
STEP 24: BUILD Complete
Final look and some different look with other material (binders for paper).
STEP 25: END
Online 3D model - https://www.tinkercad.com/things/h7xeuXKbatF
You can follow me:
- YouTube: https://www.youtube.com/diyperspective
- Instagram: https://www.instagram.com/diyperspective
You can support my work:
19 Comments
Jfieldcap 5 years ago
diyperspective 5 years ago
ZutA1 6 years ago
Thats so cool! Great build and clear instructions.
I will make one using an addressable LED PCB board with an ESP8266 and be able to remote control it using Apple Homekit.
I have been experimenting and think I will use waxed/oiled paper, which gives you an opaque look without colouring the light.
JohnC430 6 years ago
when I read the title I thought it really was a floating lamp and was visualizing all kinds of magnetic levitation approaches, and then how to light the lamp? with solar and batteries??? etc., etc. Small disappointment, but yeah, it still looks "floating" and the approach is much simpler. Thanks for sharing.
diyperspective 6 years ago
Sorry for misleading title, I changed it from floating to "floating".
I am using standard light bulb which is often powered by AC power directly from the wall. In my case 220v.
no matter what, it is still a very nice creation.
Thanks. I did not mean that it was misleading, but yeah, you made it clearer. I am an electronics engineer and have made many weird devices so my imagination took off and started designing the moment I saw the title even before I read the article.
Nah, it was a little bit misleading. The lamp has floating look, but it's not floating, so correct way of writing was - floating in quotes :)
Pra_ga 6 years ago
Truly gravity defying :)
This reminds me of the lights under the cars in Fast & Furious :D
Putting a greenlight would give you Brian O'Conner Toyota Supra!
Ha ha, yes! Good old times of F&F :)
mikea257 6 years ago
Not commenting on the lamp which is pretty cool, but wanted to say I liked how you wrote it for someone who has very little experience. No step was left left out. Maybe the best instructable I have seen for the newbie.
Thanks, that was simple project so it wasn't hard to write it. :)
LeslieGeee 6 years ago
Thank you for sharing your project. Well done and easily accomplished. Plus I love the "no exotic tools needed" approach :)
Thank you. I will try to keep using simple (or affordable) tools in my
future instructables / videos, because more likely that most people
don't have full "arsenal" of advanced tools :)
Artuino 6 years ago
nice project.very neat.
Penolopy Bulnick 6 years ago
I just love your lamp design! The way the light comes out the bottom to make it look like it is floating is great! You should consider entering it in the Paper Contest :)
Thank you very much :)
