Introduction: DIY Foam Cutter With Nichrome Wire || Thermacol Cutter
By the way, subscribe to my YouTube channel for more projects like this. I also update my upcoming projects on Instagram.
buy me a coffee! ☕: Donate
This tutorial is to build DIY Foam cutter .
The foam cutter is use to cut the foam board or thermacol board in perfect shape and size for other projects and craft.
it used a nichrome wire which heats when it connected to power supply.
Step 1: Requirements
- Pencil
- Soldering iron
- Hot Glue Gun
- Cardboard Box
- Switch
- Wire cutter and Stripper
- Wire for connection
- Nichrome Wire
- Metal Nail
___________________
- I have used 12V transformer , you can use 12V adapter instead of 12V transformer .
If you are using 12V transformer you need 4200uf capacitor and 4 diode for rectifier.
Step 2: Make the Base
- Make a Squire of 4 pencil
- Remove one Pencil from Squire
- Glue both corner as shown in photo.
Step 3: Support the Base
- make three parts of 4rth pencil
- Glue two part at the corner of Base as shown in photo
Step 4: Insert Base in Box
- Make hole at the top of Box
- Make hole at the bottom so the pencil can go into the box as shown in photo
- Glue the pencil inside the box as shown in photo.
Step 5: Add a Switch
- Solder two wire at both terminal of Switch
- Place the Switch inside the Box
Step 6: Connect Some Wires
- Solder a Wire at the Nail
- Glue it at the Top of Pencil Base
- Glue the Wire so the Wire go inside the box
- Also solder and Glue the 2nd Nail at Bottom
Step 7: Connect Circuit
- Connect the Circuit as shown
I have used 12V transformer , you can use 12V adapter instead of 12V transformer .If you are using 12V transformer you need 4200uf capacitor and 4 diode for rectifier.
Step 8: Heating Element
- Bound Nichrome Wire at Bottom Nail
- Pass it into the Hole
- Bound it at Upper Nail
Step 9: Here We Good to Go
Here WE go
- Connect the Power Supply and cut the Foam board Sharp and Clean.
