Introduction: DIY Frankenstein Bulb
Step 1.) Remove The Tab on the light Bulb
Step 2.break the insulation layer (black part)
Step 3.) Break the fialament and pulling it out
Step 4.) Add Water to wash it out if white (if clear skip step)
Step 5.) Add Gel i ended up using a different gel i used a garage door lubricate instead of the hand sanitizer
Step 6.) Add Padding to bottom of box
Step 7.) Make an outline of the cut your about to do to fit the light bulbs in
Step 8.) Cut out the holes made with 7/8 bit
Step 9.) wire the leds two both battery terminals and the switch Refer To This Diagram --------> https://www.youtube.com/watch?v=owgrUYC0Sfw&feature=youtu.be
Step 10.) Glue together and Turn On And Enjoy
