DIY Frankenstein Bulb
Intro: DIY Frankenstein Bulb
Step 1.) Remove The Tab on the light Bulb
Step 2.break the insulation layer (black part)
Step 3.) Break the fialament and pulling it out
Step 4.) Add Water to wash it out if white (if clear skip step)
Step 5.) Add Gel i ended up using a different gel i used a garage door lubricate instead of the hand sanitizer
Step 6.) Add Padding to bottom of box
Step 7.) Make an outline of the cut your about to do to fit the light bulbs in
Step 8.) Cut out the holes made with 7/8 bit
Step 9.) wire the leds two both battery terminals and the switch Refer To This Diagram --------> http://www.youtube.com/watch?v=owgrUYC0Sfw&feature=youtu.be
Step 10.) Glue together and Turn On And Enjoy
45 Comments
GladiatorShisha 10 years ago
maxninja2013 10 years ago
shalow 10 years ago
Xonk61 10 years ago
shalow 10 years ago
wannabemadsci 10 years ago
shalow 10 years ago
shalow 10 years ago
d1no 10 years ago
kenwarf02 10 years ago
hohohe 10 years ago
Needleroozer 3 months ago
lime3D 9 years ago
I'm not seeing where you are sealing up the bulb. What's keeping the gel from oozing out? Is it when you hot glue the bulb to the LED?
sillyzombie666 9 years ago
don't use hand sanitizer , its flammable so yeah not a good mix with electrity
michaelgc 9 years ago
Great diy project. I will have to wait a few months now since I am late to the party
