Introduction: DIY Friends Forever Bracelets!!!
Hi all!!!
This is the most beautiful bracelet for the friends forever!!!
So, me and my best friend have decided to make a customized bracelet together...
But.... not with the ready made beads but with colorful beads made with paper and painted with the most beautiful colors and especially we've used GLUE!!!
So, let's go check out the supplies we need...
- Blank A4 size paper
- acrylic paints
- sponge
- palette or any smooth paper
- nylon thread
- hooks and loops
- toothpick
Step 1: Painting...
The first step is to pour a little bit of paint on the palette or the smooth paper, and then dab some paint on the sponge.
Step 2: Folding...
After painting the paper fold it like a origami paper fan.
Now, cut it vertically into long triangles.
Step 3: Making the Beads...
Now apply glue and the start rolling it from the wider side of the triangular strip with the help of the toothpick...
This will make the bead...
Step 4: Joining All Together...
Use the nylon thread to bind the beads together to make the bracelet.
First cut out the nylon thread and make sure to keep it long enough (60cm approx.)
Now at the starting tie the loop and insert two of your paper beads, after inserting them from the exposed part of the thread and insert the thread from the bottom of the first bead, this will make a segment of the bracelet.Keep on continuing the same process until you finish using all the beads...
Step 5: Final Step and End Product...
Now when you're finished with it tie the hook at the end of the bracelet.
Do the same for your best friend.
Now your friends forever bracelet is done!!!
Time for you to make it too 😊😊🙂...
