Introduction: DIY Game Soldering Kit
This is a DIY game console soldering kit that includes four classic games, each with its own distinctive sound effects. The console allows you to adjust both the brightness and volume for a personalized gaming experience. Furthermore, the console features an integrated design for the casing, making gameplay more comfortable and convenient.
Step 1: Micro USB Female Socket
Micro USB Female Socket at USB.
Note: Adjacent pads cannot be blocked by tin. Or intsall it after buttons.
Step 2: Resistor, Electrolytic Capacitor, Ceramic Capacitor
10Kohm Metal Film Resistor at R1; 10uF Electrolytic Capacitor at C1; 0.1uF Ceramic Capacitor at C2.
Step 3: Toggle Swtich
Toggle Swtich at S1.
Note: Soldering iron can’t be in contact with the pins for a long time, otherwise it will damage the black plastic due to high temperature.
Step 4: DIP-40 IC Socket
DIP-40 IC Socket at U1.
Its notch corresponds to the position of the mark.
Step 5: Red 3Bit Digtal Tube
Red 3Bit Digtal Tube at LED3.
Note: 3 decimal points at the bottom.
Step 6: Red 8*8 Dot Matrix Screen
Red 8*8 Dot Matrix Screen at LED1/LED2.
Note: silk screen printing side at the bottom.
Step 7: Black Button
Black Button at S2-S6.
Ensure that each pin is fully inserted into the soldering hole.
Step 8: S8550 Transistor
S8550 Transistor at Q1.
Pay attention to the installation direction .
Step 9: Buzzer
Buzzer at LS1.
Note: the ‘ + ’ pin is positive pole and connect to the ‘ + ’ pad.
Step 10: Insert STC15F2K60S2
Insert STC15F2K60S2 into IC Socket.
Note: Its notch markings are used to determine the installation direction.
Step 11: Red Button Cap
Place red button cap on black button.
Step 12: Metal Battery Connector
Metal Battery Connector with spring is negative pole.
Cut ONE pin from negative.
Insert them to the corresponding position.
Step 13: All Pins
All pins are bent outward.
Step 14: Add Soldering Tin
Add soldering tin on the positive and negative electrodes.
But avoid damaging the casing due to high temperature.
Step 15: Wire Connection
Red wire connect to positive pin and black wire connect to negative pin.
Step 16: Wire Connection
Red wire from battery box connect to ‘ + ’ pad on PCB and black to ‘ - ’ pad.
Step 17: 3pcs AAA Battery
Install 3pcs AAA Battery.
Note: batteries are not included in packing. Users need to prepare your own batteries.
Step 18: Black Sponge
Place black sponge on battery.
It’s used to prevent the battery from loosening or damaged by solder pad pins.
Step 19: Fix the Casing
Adjusting the battery wires and Align screw fix installation holes.
Fix the casing, but do not apply excessive force, otherwise the casing will be damaged.
Step 20:
Product Link: https://www.amazon.com/dp/B0D6YRS472
